Question about Haier HWR06XC5 Wall/Window Air Conditioner
No longer cool
Our window unit is two years old and while cool air does come out, it is not cold. We used to wake up freezing. Now I wake up because I feel warm even with the window unit on. We cleaned the filter. What else could we do?
    Scholar:
  • 121 Answers
If the unit is operating normally but not cooling properly than you are low on refrigerant.
Posted on Oct 01, 2008
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
My ac window unit. Can I make it colder.
U do not have control over the temperature of the air; you can control how long the compressor operates with the thermostat. A longer running time equates to a cooler room.
Clean condenser out to maximize efficiency and cooling.
Jul 29, 2017 | LG Heating & Cooling
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
Window air conditioner loud when compressor kicks in
Possible that compressor motor internal mountings broke.
Apr 07, 2010 | Heating & Cooling
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Not cooling
did you unplug it for about 8 hours to make sure that it is completely defrosted? These new side by sides use cold air to cool them unlike the good old freon tubes running aroung the inside like the fridge your grandmother had for 50 years. They freeze up easy and take for ever to thaw out. check the seal around the bottom of the door to make sure it is not broken or hanging loose.
Mar 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Not getting cold anymore
Unit has probably lost its charge of refrigerant.
Check for warranty, or buy another one.
Usually they are not worth repairing, sorry
Jun 06, 2008 | LG Goldstar GWHD5000 wall/window Air...
Haier HWR06XC5 Wall/Window Air Conditioner Logo
218 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
