Question about Dishwashers
Soap residue on all items after dishwasher completes its cycle.
Maytag jetclean dishwasher EQ plus. Not cleaning properly. Soap residue left on all dishes and eating utensils. How do we rectify this problem? We have tried different detergents to no avail.
Seems this is problematic with other dishwashwers. Would greatly appreciate some feedback as to how to sovle this situation. Thank you.
  • 39 Answers
Hi Rioski
The first thing to do is where you put the jetdry turn it down to one. use powdered detergent the best is electosol is the blue box,dont use the heated dry feature and run the hot water at the sink first to get it good and hot that should fix the problem. I also recomend using GLISTEN every 6 months. its a citric acid that is designed to clean the dishwasher. i hope this helped.
Posted on Oct 01, 2008
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
What is the model number?
Jun 04, 2013 | Dishwashers
There is residue left on my dishes(mostly cups and glasses) when washing cycle is completed. How do I wash my dishwasher?
Hi domenicadice,
Look at my tip below on some simple things you can do to ensure your Dishwasher is washing correctly:
Kind Regards
* If this solution helped you, please rate it
Jul 21, 2011 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Check that the upper and lower wash arm holes arernt obstructed with debris,also check the screens in the unit for obstructions.Is the water hot as before you had this issue?let me know.
Nov 26, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
401 people viewed this question
Top Dishwashers Experts
