Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi 60" I believe 1997 Model
We turn it on and there is no picture but the sound is ok. It seems like there are lines that come across the screen then it goes out. I was told by a friend that it was the Vertical Hold but I am not sure.
Please help.
  • 142 Answers
You need a new PIP module. Surface mount capacitors have leaked out electrolyte and damaged the PIP PCB.
Posted on Oct 01, 2008
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
