Question about HP Deskjet D1430 InkJet Printer
Printer doesn't print full page
The printer is only printing the top and bottom of the page. Nothing in the center of the page prints. Why?
    Genius:
  • 1,913 Answers
Check your toner cartidge try to change it.
also check your fuser assembley clean it nand refix, it
thats all.
it you rrprinter problem not computer
Posted on Oct 01, 2008
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Prints no ink
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1300 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 14, 2012 | Lexmark Z1300 InkJet Photo Printer
Making noise like its printing but nothing comes out on paper
  2. Go to Programs.
  3. Go to Lexmark 4800 Series folder.
  4. Select Lexmark Solution Center.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Alignment off
If that doesn't help, please try this approach:
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Not printing
  2. Go to Programs.
Nov 29, 2011 | Lexmark Z600 InkJet Printer
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
It prints improperly, dark on top then fades to nothing.
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.On your computer, open your Kodak AiO Home Center software.
b.Click on the Help (?) button.
c.Click on the Maintenance option.
d.Click on the Clean Printhead option.
3.Print Demo Page.
Press Scan and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
HP Deskjet D1430 InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
