Question about HP Officejet 6310 All-In-One InkJet Printer
Scaner computer comunication
I would like to scan document and e mill it to costumer, but scaner and computer dont comunicate , how to make tham
thank you hp officejet j6480
  • 234 Answers
These are the steps for Windows operating system.
First make sure you have installed the printer driver software installed sucessfully untill it shows fax setup wizard and complets the entire procedure.
All you need to check is first open solution Center> Go to Settings> And Email Settings> Checked which is the default email selected there if you have outlook select it (But your outlook has to be configure to send Emails fom youe PC) then click on apply and close.
Then in solution center click on scan picture or Scan Document the in the next window where you see (Where do you want to send the scanned images) Click on the drop down and select EMAIL after it has scanned and you click on accept it should open the outlook window on its own where you can put the recepients name and send.
But if in case your outlook is not configured then try the bellow link to configure outlook:
http://www.hostmysite.com/support/email/outlook/
You can also send email from the printer but to enter email address you will need the computer to manully enter email address after it opens outlook window
Good Luck let me know if any problem
Let me know if any problem.
Good Luck
Posted on Oct 01, 2008
Obd2 scan tool don't comunicate with the pcm, what to do?
Carlos, see if there is a fuse blown to the OBD2 port, the obd port some time shares with other accessories/things like cigarette lighter.
Check all fuses, the OBD will not work if fuse is blown.
May 08, 2016 | 2000 Mazda MPV
2004 touareg steering defective workshop on screen my scaner will not comunicate will not start or crank.can anyone help?thanks
start with the battery if it won't crank. turn headlights on and try cranking. If headlights r bright then go very dim when cranking chk batt terminals. If headlights r dim before crank, chg or replace batt.
Sep 21, 2014 | SCOSCHE Vw 03-06 Touareg Installation Dash...
2006 ford taurus se chek engine light on and not comunication with scaner
The OBD connector may be dead - the cig lighter fuse may be blown.
Or it could be a problem with the engine computer.
Jul 14, 2014 | 2006 Ford Taurus
No bus comunication with abs
If you are using a common code reader, most are not designed to read codes from body computers.
If you are using a professional scanner, you may need to check the harness between the PCM and the body computer.
Jul 24, 2012 | 2007 GMC Sierra Classic
Scaner motor doesnot stop
If your scaner motor continues to run or skip while the unit is first powering up there is a problem with the comunication from the scaner to the main system board in the back of the unit. This is not an issue that can be resolved with out voiding any warranty since you will have tp remove the back plate of the printer. Most common causes bad scanner motor, dirt or toner dust in the conections to the main board, or a damaged data cable(silver).
Sep 10, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
I CAN NOT PRINT FROM THE COMPUTER IT PRINTS ONLY WHEN I SCAN SOMETHING DIRECT ON THE PRINTER
Most probably there is comunication problem between the printer and the computer. Have a look at the comunication cable, try another cable or reinstal the printer again. GOOD LUCK.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
01 WV jetta comunication error when trying to use the obd scaner
I worked on a Jetta with a similar problem of no communication. By chance do you have an aftermarket radio in the car? If so the buss lines that carry the vehicle comunications may not be connected thru the radio. The data lines run thru all the computer modules so they can talk to each other. This could be the problem.
Nov 21, 2008 | 2002 Volkswagen GTI
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
