Question about Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier
How many batteries do I need to run a coleman 1500 watt power inverter
The unit I have is a Coleman, is there a way to change the shutdown voltage? I am sure this is outside of the normal customer.
Posted on Oct 01, 2008
  • 631 Answers
It would depend on the load being driven by the inverter (which would determine the current drawn by the inverter), the capacity of the batteries and the shutdown voltage of the inverter.
Installing a 1500 watt inverter on a frieghtliner cascadia
You dont want to install directly to the battery as the battery will constantly produce energy draining the battery instead install it to the yellow ignition wire usually accessable under the dash so as it only runs when the vehicle is on You can also usually locate the ignition at the fuse panel
May 20, 2012 | Cobra Electronics 1500 Watt Triple-Outlet...
My cobra 1500 watt inverted doesn't come on wen I
You may not have adequate input voltage. And unless you are hooking up to a forklift battery, the battery will not have adequate current delivery capability for any more than a few seconds at full power of the inverter.
1200 Watts is 100 Amps. 1500 Watts is in the neighborhood of 130 Amps.
Jan 17, 2012 | Cobra Electronics - Others
Microwave wont run with a 1500 watt inverter why
Depending on the model of the microwave it could draw more wattage than what is put out by the inverter. Don't forget there is a inital spike when your unit first starts and that although an inverter might be listed at 1500 wat that is the maximum and will depend on how much power the inverter is getting in, so if the engine is not putting out enough power the inverter will not put out a full 1500.
Aug 30, 2011 | Electronics - Others
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
Have a coleman 2000 watt 24v dc power inverter. When using it for a short period the temperature light and alarm sounds. The can just be a tv. The watt meter on the panel don't event light up. What the...
If you are only tring to run a TV off this inverter, it appears you may have a defective unit. If you have had this inverter for only a short time, contact the dealer/store where you bought it and seek their advice. If you have had it for 90 days or more you can still contact the dealer, but maybe it would be best to contact the coleman company. You can go to their website nad find out how to contact the division that deals with this particular type of product.
Mar 23, 2011 | Coleman Cable Coleman 1000 Watt Power...
Why would my new 1500 watt inverter readout show overload 13.8 volts entering
It would show overload if you're drawing more power than it can supply. 1500 Watts is a very high output for an inverter but that is the maximum it's capable of. As with any electrical supply you should not draw the maximum power it's capable of as this can cause it to burn out. Around 1200 would be the max you should draw continuously. You need to check the power requirements of whatever you're running on it. Also you need to check that it's capable of taking 13.8 volts. If 12 volts is the recommended input, putting in 13.8 will increase the voltage output which could damage appliances being run on it.
Jan 10, 2011 | PowerBright New 1500 Watt 12V DC to AC...
Can I back feed through my inverter from a generator to charge my batteries?
What does it invert?Higher voltage to lower or what?Either way,with 1200 watts being inverted,it is not a good idea to charge a battery with that kind of power.Batteries need to be charged low and slow.We are talking milliamps for hours.Fast charging a battery results in a very good chance of explosion,which is never good.Acid from the battery will go everywhere.
Aug 04, 2010 | Coleman Cable Power Inverter PMP1200
My inverter is in alarm and won't produce 110 power. Checked input voltage and it is correct.
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 26, 2010 | Coleman Cable Coleman 1000 Watt Power...
Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
Sep 01, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier Logo
238 people viewed this question
Top Statpower Car Audio & Video Experts
xxxxxx xxx
Are you a Statpower Car Audio and Video Expert? Answer questions, earn points and help others
