Question about Breville SK85XL Nova Cordless Electric Kettle
Leaking spout - Breville SK85XL Nova Cordless Electric Kettle
  • liquidate Oct 01, 2008
    Thanks Jerry.I still think it is a shame to throw it out . There must be a cheaper alternative.
    Genius:
  • 1,689 Answers
The spout is electro-welded on to the shell. The most feasible solution is to replace the kettle. If you want to pay the cost for electro-welding, this would not be cost effective.
Just to let you know, electro-welding is not soldering as many people confuse it. The process is very different.
Jerry G.
Posted on Oct 01, 2008
  • Jerry Greenberg
    Jerry Greenberg Oct 02, 2008
    You will have to do some research. Maybe you will invent a new method of doing electro welding!
    Jerry G.
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
Vita Bath, Paradis whirlpool tub waterfall spout leaking inside tub deck. Plumber has siliconed it, but leak remains. It seems the 2 piece spout is maybe a design flaw??
sounds like a design flaw or installation flaw. I would contact the MFg of the waterfall valve and see if they have a solution for the leak.
Silicone in something like that would be a temporary solution at best.
US PART CENTER
Aug 15, 2011 | Whirlpool Paradis Air Bathtub By Vitabath...
New spout leaks does the copper pipe go to the rubber ring or does it have to go by it
Tub spout has an o ring that pipe goes through for seal. So it should go by it.
May 15, 2010 | Danze & Single Handle Tub And Shower...
I have a moen fawcett. single knob, it is leaking
the spout is the end piece where the water comes out. where is it leaking ?.
when you put it back together i would suggest you use some teflon tape often called plumbers tape on all the theaded fittings as that will prevent any leaks as well.
Nov 27, 2009 | Moen & One Handle Tub & Shower Faucet
Delta RP34357 Traditional Diverter Tub Spout has been leaking around base and/or water running along bottom of spout toward wall from opening; today, whole spout blew off wall when faucet was opened only...
If this spout is less than one year old, I would contact my general contractor to get his plumber over to look at it. Most GC's (general contractors) will warrant their work for one year. If it is not under warranty, you should be able to fix this problem. Spouts do not typically blow off like that, so I am wondering if there is not an underlying circumstance. At any rate, I will assume the best and tell you how to reinstall the spout. There are several variations on spouts, but the one that is most common is a slip connection. Meaning that the spout will slide over a 1/2" copper water line protruding about 3" from the tub. After sliding the spout on, there is an allen screw on the bottom of the spout that snugs up against the copper pipe (again this is the most common type of install). If yours is different, let me know, and I will walk you through other processes. Before sliding the spout back on the copper, use plumber's putty around the opening that the copper is sticking out of. This will help to prevent water from getting behind the tub. Also, after the install; check the spout to make sure there are not any leaks. If no leaks are detected, use a clear silicone tub/shower caulk and go around the faucet. The caulk does not have to be a 1/4" bead to be effective. Run it around the spout, and using a moist towel, go back over the caulk to remove the excess. If you have done it right, you will not even notice the caulk, except for the gaps. Hope this is helpful.
Nov 20, 2009 | Delta RP34357 Traditional Diverter Tub...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Dec 29, 2008 | Plumbing
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Breville SK85XL Nova Cordless Electric Kettle Logo
117 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
