Question about HP Deskjet 5440 InkJet Photo Printer
Hp printer replaced ink cartridge with #99 photo. will only print in b
  • brodiddle Oct 01, 2008
    they are both unchecked. the only other option is high quality which is checked.
  • veisler Oct 10, 2008
    same problem. both boxes are unchecked.
    test page works only in black
    when I try the color calibration the message is that the current configuration does not support that service.
    Scholar:
  • 45 Answers
Have you checked (Right click on printer name) "Printing Preferences", "Color"?
"Print in Grayscale" and "Black Print Cartridge Only" should be Unchecked.
Hope this gets it...
Label_Guy
Posted on Oct 01, 2008
What are the ink cartridge numbers for this printer?
The OfficeJet 7310 can use different ink cartridges:
Black: HP 96 or HP 94 (high capacity - lasts for ~860 pages, if it doesn't dry out.)
Color: HP 95 or HP 97 (large capacity)
Photo: HP 99 (replaces black when you print on Photo papers)
Photo Grey: HP 100
See http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00227021&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=391182 for the parts list of this printer.
If you were using the wrong ink cartridges, you would not be able to print at all. HP printers give errors when it doesn't recognize the cartridge as the appropriate one.
First check if you are printing in a low quality mode. This is under Printer Properties or Printer Preferences when you click Print or right click on the Printer in the Devices Control Panel. Go to the Printing Shortcuts tab. In the Advanced Options (click the button), you can change the ink volume and slide the tab to the right to add ink.
You should print a Diagnostic test page to see the color levels/reproduction relative to the HP settings and consider cleaning the print head. The diagnostic page is reached by pressing * and # on the printer. Then press 1, 2, and then 3. In this Service Menu, press the right arrow key twice and press OK to open the Special Reports menu. Press the right arrow key once and then press OK. See http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00242761&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=391182 to evaluate the printout's ink cartridge quality information.
I've seen dull colors on photo paper when you print on the wrong side. This is obvious since the ink will bleed.
The other common issue is differences between the color appearance on the monitor and the printer reproduction of that color.
I hope this helps.
Dec 28, 2012 | HP OfficeJet 7310 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
I have a Deskjet 6940 printer and ive bought a HP348 photo colour ink cartridge. it wont fit in the slot!? Does it go in the colour slot?
Your printer doesnt support HP348 cartridge.
HP 99 Photo is the cartridge meant for 6940 which wud go in the slot for black cartridge. and you can print approx 130 photos .
Mar 28, 2009 | HP Deskjet 6940 InkJet Printer
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP Deskjet 5440 InkJet Photo Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
