Question about HP Office Equipment & Supplies
Icannot find out how change from one cartridge to another.the print cartridge is set on yellow and i want to print in black
  • 58 Answers
In print settings change Color to Grayscale mode!
Posted on Feb 19, 2009
I70 Canon photo printer will not print after changing print cartridge.
Check the black cartridge and make sure the orange or yellow tape at the rear end is not still attached. If it covers the small hole on the top of the cartridge, the printer won't print black text.
Mar 09, 2012 | Canon BubbleJet i70 InkJet Photo Printer
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
I have a dell 3110 and my yellow cartridge needs to be replaced, i need to print documents asap , how can i print them in black (without the yellow cartridge being replaced), i need to reorder it but no...
When printing a document, after you press print, select preferences of the printer and at the bottom there is an option for output color. change that to black and you will be all set.
Jan 30, 2009 | Dell 3110cn Laser Printer
46 people viewed this question
Seeker5211
Seeker5211
