Question about Sony DAV-DX250 System
Wont play disk has error code
Code is somthing like this C-13-3-70
The Problem: I stuck a disk in and was watching it then it froze up and shut down, I took the disk out and it was really dirty, when i stuck another disk in including a cleaning disk, it says "No Disk" or *DISK 1* and nothing else. every so often when i push play it scrolls the error code fast "C-13-3-70
Everything else on the system works fine.
lbclassics@gmail.com
Pierre
  • Sony Master
  • 19,396 Answers
It is a lens problem, the laser lens is either dirty or the lens pickup is faulty.
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on May 04, 2009
Error code 80029940
It sounds like a disk read error. In the future please supply information on what you were doing win the error occured. i.e. playing a video game, watching a Bluray movie... etc.
Likely that the movie itself is the issue. Try unconnecting your PS3 from the internet reseting and trying to play the video again without your PS3 connected to the internet..
Good luck.
Jul 16, 2011 | Sony Playstation 3 (PS3) Console
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Ps3 wont reconize any discs after freezing
The error code 80710102 you are getting due to a possible connectivity issue of your PS3, since you have not specified in your problem how are you trying to connect your PS3 to internet so i am unable to assist you on that front
For the problem related to discs not playing is becuase ps3 files being corrupt.
1) First take a back up of your data on PS3 - Go to system settings> backup and follow the appropriate settings,i suggest use a usb stick or hard drive to back up your data.
2) Under system settings go to restore ps3 and follow instructions. This will erase all the data on your ps3 and restore it to its factory default, this will restore all the original ps3 files.
3) Once the PS3 install has completed then try updating your PS3 to latest firmware available, now try playing your discs
4) If your ps3 now plays games and dvds go back to system setting> backup, select restore previous back up and all your saved data will be imported from the hard disk, please note: you may not be able to restore any copyright stuff which you could have purchased.
5) If the above steps do not work, kindly send your PS3 for repairs to Sony Customer Service
Hope This Helps
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My mt6840 froze up. I couldn't get it to restart. I finally reinstalled Vista but I'm not sure how to unintall all the old software. my disk space is extremely low
just delete it.if any files are being used by vista just update them with the disk.
But what i would do is salvage as much of your work etc..as you can, put it on CD or somthing
then switch it off & go into the BIOS when it comes back on.Its F2 or F8 or somthing like that it will tell you,then set the BOOT ORDER so that CD is at the top of the list.
put the vista disk in & reboot it then follow the instructions & just make shure you select the option to format the disk ( C:/LOCAL DRIVE)
DONT DO THE QUICK FORMAT.
GOOD LOOK MATE.
if you get stuck E-Mail me.
Aug 08, 2009 | Computers & Internet
PS3 Error message...
This is the error code for disk errors: "An error occurred during the start operation. (8001002B)". If the disc is clean, maybe the laser is dirty. Use a lens cleaning CD to give the laser a clean (cheap to buy). You can also try deleting the temporary game data (using Game Data Utility) and reinstall the game.
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
Error Code 07 301
With IBM Thinkpad,it telling you that some hardware is faulty, check your keyboard to make sure nothing is stuck. Also it could also be your trackpoint. Usually, replacing the damaged part gets rid of the error! However there is a bypass key sequence that allows your to continue booting the system even though it gives you error. I'm not 100% sure of what it is but somthing like ESC at boot or F1 or maybe your need the boot to the error page then press ok, then when the system comes up again press f1 or esc then. You'll have to play around with the key sequence a bit. But to get rid of the error forever you need to replace the damaged part! Regards, Armando
Apr 28, 2007 | IBM ThinkPad 600X Notebook
Sony DAV-DX250 System Logo
398 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
