Question about PreSonus Firebox 6x10 External Sound System
Doesn´t work anymore
Connected my laptop to the firebox and the blue (or red) light doesn´t turn on anymore. The same happened when I plugged the power adaptor. The computer doesn´t recognize it anymore. It´s weird because it was working perfectly a few hours before and it happened without an apparent reason. It didn´t fall from its place or was hit.
  • 3 more comments
  • Anonymous Oct 25, 2008
    i was using it and then the next minute nothing, nada!
  • Anonymous Nov 29, 2008
    i got the same problem... who can i send it out to?
  • traceys_home Dec 08, 2008
    Same here, have used my Firebox for almost three years. I moved my PC into another room and it stopped working! I have encountered problem after problem w/ Firebox. It worked then minutes later stopped and now the PC doesn't recognize Firebox.
    What gives? Anyone?
    Pasadena, CA
  • Anonymous Jan 12, 2009
  • Anonymous Mar 20, 2009
    exactly the same!
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Posted on Jun 30, 2009
How can i get the red light on my kaider speaker to turn blue?
You can purchase LED red and blue emergency strobe light for your truck for $35.99 with free shipping online at http://www.gadgettown.com. ------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 06, 2013 | Cars & Trucks
I have a Toshiba Tecra-M2-S410 machine, and it does not turn on anymore. When I remove the battery and plug it in, the power light turns green as expected. When I press the power button, two other lights...
Hi mohammad - seems the LCD of the laptop is gone bad . as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Oct 01, 2010 | Toshiba Tecra M2-S410 (032017233812) PC...
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
My firebox just seemed to stop connecting. the blue light comes on for a second then goes red on both firewire ports...is it my fire wire card on my pc or the firebox?
IF YOU HAD ANY RECENT UPDATES ON YOUR PC.IT MAY HAVE CHANGED SOME DRIVER SETTINGS. UPDATE YOUR DRIVER ON THE PRESONUS WEBSITE. IT COULD ALSO BE A BAD CABLE.
Jul 10, 2009 | PreSonus 6x10 Firewire Recording Interf...
Gateway laptop randomly shut off and wont come back on
Try removing the battery and see if will start up with power adapter. The battery may have failed. If it is a couple years old the battery may need replaced.
Apr 01, 2009 | Gateway Computers & Internet
I need help resetting firebox firewall password
You can always do a hard reset to the soho, but backup your system settings for this will factory reset the box because it will erase everything!
1) Unplug any devices from the all ports.
2)Unplug power cord.
3)Use paperclip to hold reset button.
4)While continuing to hold the reset button plug the power back in.
5)Watch the status light in front, when it turns on(the red light) wait until it turns back off, then release the reset button.
The whole reset process is about a one minute wait for the status light.
Dec 01, 2008 | WatchGuard Technologies FireBox SOHO 6...
PreSonus Firebox 6x10 External Sound System Logo
772 people viewed this question
Top PreSonus Computers & Internet Experts
Marcin
richie46
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
