Question about Intertherm Heating & Cooling
Wiring diagram for Intertherm (Nordine) Model e2eb-023ha
  • 96 Answers
SOURCE: heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Posted on Dec 10, 2008
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
  • 30 Answers
SOURCE: need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Posted on Jan 05, 2009
flatech
  • 111 Answers
SOURCE: I need a wiring diagram for a intertherm model #
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Posted on Nov 03, 2009
  • 99 Answers
SOURCE: Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Posted on Feb 20, 2010
I have a intertherm model e2eb-017ha the blower wont shut off i have to turn the braker off
One The blower relay is stuck in the on position. Two at the thermostat, fan switch should be set to auto. Set it on the blower wont quit.
Jan 29, 2014 | Intertherm Heating & Cooling
My furnace keeps blowing fuses why it is a nordine model #e2eb-015ha
The first thing i would do is shut off all the power to the unit and disconnect all the wiring from the thermostat. then i would install a jumper wire from R to W on the circuit board and see if the furnace runs good. if it runs good and does not blow a fuse, your problem is in the wiring between the t-stat and the furnace. If this does not help, please indicate if your system is a straight a/c, furnace system. or if it is installed with a heat pump. also does it make any difference what the temperature is outside. for example, does the fuse only blow when the temp drops down into the 30s or does it not make any difference.
Nov 19, 2010 | Heating & Cooling
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
I need an installation instructions for a
Hi, This is a very popular unit. Call you're local wholesale a/c parts house with all of the info on this 2 1/2 ton unit, and they can help. Have you tried going online to search for this? Would also try this. Good Luck,
Shastalaker7
Nov 12, 2009 | Intertherm P3RC-030K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Need help bad!!!!
Jan 04, 2009 | Heating & Cooling
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Heat comes on fan does'nt
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
1,290 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
