Question about GE (PSS26MSRSS) Side by Side Refrigerator
Gss22ifrf All of a sudden the ice dispenser does not work. It is dispense water but not ice eith as whole or crushed. Like the motor is not working. Is there a way to reset it or any other suggestions
  • jimandama Oct 05, 2008
    water despenser is fine, replaced filter. seems like the ice maker doesn't fill
    ice does not fill, replaced filter, water in door is fine
  • 943 Answers
Hi. is the arm on the ice maker, in the down position. check that. if down check the water valve at the back. pull away from the wall. remove back panel. clean all coils. check the water valve.
Posted on Oct 06, 2008
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
121 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
