Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
My water filter is stuck!
I have the same problem. Did you get yours solved? did you force it out?
  • 120 Answers
Need more info where is the filter located bottom top if is in the bottom remove the grill so you can get a better look and grip
Posted on Oct 31, 2008
Stuck pump cover
OK..Got It! Your filter has disconnected from the Drain Pump. You need to have the machine's cover removed and re-attach the Filter back on to your Drain Pump! OKey...Dookie?
Jan 16, 2014 | Siemens Washing Machines
Filter stuck
It could be frozen, allow it to heat up some and try again. If not remove the filter cover and the filter will be easily removed.
Jun 30, 2013 | Electrolux Refrigerators
GroundFOS water pump won't stop running after replacing PVC pipes
you may have to blead air from the water lines. air pokets will not let your pump regulaet. as your pump feeds water into the filter and all your house hold pluming it must reach a set presher. if ther is air trapt in the sistem it can not build enouph back presher to force the pumps PSI regulaeter switch to ingaidge. air is lighter then water ther for thes to difrent forces pushing against one another couses a flucksuaition and can not regulaet. blead all lines from the pump to all outlets"fosets,spikets and filltering sistem. let pump run while going to all outlets one at a time opening and closeing "cold side first" them to releave the air from the lines. donot forget eny outside fosets this should solve the problem. thank you for leting me help you today .
Feb 17, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Reverse osmosis water filter
Hi jennym123,
I'm Harvey the Master Plumber.
Your question is: You have a reverse osmosis water filter. The other day water production went from over a gallon of filtered water to 3/4 of a cup. You changed the filters thinking that may be the problem, but that did not solve anything. What else could be wrong with it?
This is a common problem. Can also be very frustrating. A small bit of debrie has been brought up by the flowing water and is stuck somewhere. As you can imagine this will restrict the flow. I would start with the on/off valve next to the cold water line first. Turn the water off first and take it apart checking for obstructions. Then work your way down checking the lines and any place you can. It's helpfull to have a bit of wire to probe with. If you turn it back on and the problem still persists then you missed it. Try again. Good luck.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 16, 2008 | Home
Need to replace or remove water filter cartridge from our Whirlpool refrigerator. Cannot turn the cartridge cap to the virtical position in order to remove it. It is stuck or frozen. Afraid to use...
Called company.  Have to eliminate water pressure by moving refrigerator out and turning off incoming water from line in back.  They said water pressure was preventing cartridge cap from turning.
Jul 18, 2008 | Whirlpool Refrigerators
How do i change the water filter... its at the bottom front of the fridge in the grill part. I tried twisting but i dont want to break it
Push in and twist. If it is stuck you may have to use a little force. Make sure water is off before you use any force, because if you break the filter housing water will go every where
Jul 17, 2008 | KitchenAid Refrigerators
I cant get the filter out of my washing machine help please
you probably have something like a bra wire jammed in there. no option but to pull real hard with a pair of pliers.
smell is not caused by filter. often smell is due to using liquid detergent. after you have done filter, put on the hottest wash and change to powder detergent
Jul 17, 2008 | Washing Machines
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
