Question about Kenwood Audio Players & Recorders
KTC-H2A1 satellite receiver has lost its audio output
  • W4HNC Oct 01, 2008
    Kenwood HTC-H2A1 Satellite Receiver has lost the audio output. I see no settings that would indicate a mute setting Any other ideas?
    Display shows channels properly and music being received. Situation is same in both house and car docking.
    Genius:
  • 2,035 Answers
Turn the power off (press the
POWER button), wait 5 – 10
seconds, then turn the power on
again.then power on t and check if the system sound is coming ..............
Good luck...
Posted on Oct 01, 2008
  • 790 Answers
Hi
Check the settings on your unit maybve you are in mute mode.
Thanks
Likha
How do I get audio through the receiver instead of the tv speakers
The TV will have either a Digital Output, Optical Output, and simple RCA jacks, left and right analog. Use any open input on your receiver, and switch that input to digital or analog, whichever is appropriate for the input signal you are using. You can also take the audio output directly from e cable or satellite receiver and wire it into you receiver, as I mentioned above.
Jul 14, 2014 | Onkyo TX-SR608 Receiver
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
2-3 years old, acquring signal, not ant-error,
Do you get audio out of the stereo jack? Do you have the proper antenna with TWO leads for TERR and SAT ? It could also be as simple as your antenna alignment not being to the SW, or you could have had a local repeater get shutdown. Also, this radio is several years old (designed in 2001) and could be 'shot' already from heat damage as these get really hot. I would try the radio in the car with a car antenna perched on the roof and see if it works; if it does, then it's your antenna alignment. Good luck my friend and report back please.
Jan 09, 2010 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
Denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
solutiondoct
Mar 09, 2008 | Denon AVR-2807 Receiver
Signal Interruptions - Static
I hope that you have had this unit for a while because it has been out of date for quite some time. I had this unit as well and furtunately the problems exsisted while under warrenty and I was able to get it fixed. Version 2 seemed to be better, the (A2). Sorry for the info, but vA1 was a bad unit if you ask me.
Jun 15, 2007 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
