Question about Apple iPod nano
My ipod will not show my music on the computer but it shows that i have alot of music on my ipod but when i pug it in to the computer and click on computer and my ipod it says that there is nothing on my ipod but i can listen to all my music on my ipod now please help me my email address is kattieboo14@yahoo.com
  • 2,071 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Hopes it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Oct 10, 2008
Tip
How to add music on an ipod that is syned with another computer
Syncing music manually
If you prefer not to automatically sync music content to your iPod or iPhone, you can set up manual syncing.
Connect your device to your computer and open iTunes.
Select your iPod or iPhone in the Devices section on the left side of the iTunes window.
In the main iTunes browser window, select the Summary tab.
Select the option to "Manually manage music and videos" or "Manually manage music." This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting those options in each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting it from your computer.
Click Apply.
To manually add music, audiobooks, movies or TV shows, choose one of these categories under Library on the top-left of the iTunes window.
Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod or iPhone icon under Devices.
To add a playlist, select it from the left side of the iTunes window and drag it onto your device in the same way.
When you are ready to disconnect your iPod, select it under Devices and click the eject icon next to it.
on Apr 15, 2010 | Computers & Internet
How to tranfer the song from ipod classic to pc
Hi Kelvin, if you want to know how can you transfer music from iPod to computer, you can find it not hard to accomplish with your computer. Here are the steps.
1. Plug your iPod to computer with the USB cable. The computer will read your iPod as an external disk.
2. Double-click your iPod icon and open it. Click "Tools" in the toolbar, then Folder Options > View > Show all hidden files.
3. You will find a folder named "iPod_Control". Double-click to open it and you will find all the songs in your iPod, but they are randomly organized.
4. Copy and paste the files to your computer, and then launch iTunes.
5. Click Edit > Preferences > Advanced, and then click the "Change" button to choose the folder which is used for saving the iPod music files.
6. Check "Keep iTunes Media folder organized" and click the "OK" button at the bottom of the window.
Then you can both get the iPod music in your computer and iTunes Music Library. This is a very useful trick for the users to extract music from iPod. iTunes is one-way transfer software, so it only allows you to transfer music from computer to iPod, but never transfer files back.
http://www.leawo.org/tutorial/how-to-extract-music-from-ipod.html
Jan 03, 2017 | Audio Players & Recorders
No music on ipod player
In itunes with your ipod plugged in, click on your ipod which will show up under devices. From here you can then go to music tab and make sure you click on sync music then you can choose what artists and playlists to choose.
Hope this helps
Nov 06, 2009 | Apple iPod nano
I have a apple ipod classic it won't download music from itunes
iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
Products Affected iTunes, iPod nano (3rd generation), iPod classic, iPod (5th generation)
Syncing videos automatically Connect your iPod to your computer and open iTunes. Select your iPod in the DEVICES section of the iTunes Source list.
In the main iTunes browser window, select the Music tab. Select the checkbox labeled "Sync music" and verify that the "Include music videos" checkbox is also selected. You have the option to sync all songs and playlists or selected playlists.
Movies can be automatically synced to iPod. Select the Movies tab and select the option to sync all movies, selected movies, or a certain number recent unwatched movies.
TV Shows can be automatically synced to iPod. Select the TV Shows tab and select the option to sync all TV shows or selected ones. You can also determine which episodes are synced based on if they are recent or unwatched.
Video Podcasts can be automatically synced to iPod. Select the Podcasts tab select the option to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new or unplayed.
Click Apply and iTunes will begin syncing the content you've selected to your iPod. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
The iTunes LCD will display the sync progress and notify you when the iPod sync is complete.
To disconnect your iPod, select it in the Source list and click the eject icon.
Syncing videos manually If your prefer not to automatically sync video content to your iPod, you can setup manual syncing.
In the main iTunes browser window, select the Summary tab. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.
Click Apply. To manually add music videos, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a video or song.
When you are ready disconnect your iPod, select it in the Source list and click the eject icon.
Mar 11, 2009 | Apple iPod classic MP3 Player
My Ipod doesn't show up on Tune Tools
Try Yamipod. This is a free program that transfers music from iPod back to the computer. However, it does not transfer playcounts/ratings etc.
Chris (ziraffa)
Jan 11, 2009 | Apple iPod classic MP3 Player
Music wont show on Ipod, but does on Itunes
Please make sure that your music is in the proper format. It is best if it is in MP3 format. You can tell what format the music is in by right clicking on the music file and then clicking 'properties'. You can convert the files to MP3 by using the Media Player that comes with all windows computers. Hope that helps.
Dec 15, 2008 | Apple iPod nano
Ipod classic 120g.memory problem
Here is one answer, from the apple website:
Syncing music manuallyIf your prefer not to automatically sync music content to your iPod, you can setup manual syncing.
  1. Connect your iPod to your computer and open iTunes.
  2. Select your iPod in the DEVICES section of the iTunes Source list.ht1351_7.jpg
  3. In the main iTunes browser window, select the Summary tab.
  4. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.ht1351_8.jpg
  5. Click Apply.
  6. To manually add music, audiobooks, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list
  7. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list.
  8. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a song.ht1351_9.jpg
  9. When you are ready to disconnect your iPod, select it in the Source list and click the eject icon.
Nov 18, 2008 | Apple iPod classic MP3 Player
My Computer and iTunes does not recognize my iPod
thats happened to me before I made a new account on my i tunes and there is no sync on i tunes what ever song you want you click hold and drag to your music list
Sep 05, 2008 | Apple iPod touch
Ipod
this is how i did that to. open iTunes then hold ctrl+, a window should open you click ipod. ok then you should click manually manage songs and playlist. open my computer. click on the usb drive where your ipod it in. make sure you computer shows all the hidden files. open ipod_control they shouls be 3 folders open the folder that says " music".they should be a hell of alot of folders in that folder. part 2 in one day i got bored
http://forum.ecoustics.com/bbs/messages/15118/128017.html
Dec 14, 2007 | Apple iPod nano
Apple iPod nano Logo
115 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
