Question about Jenn-Air Kitchen Ranges
I have a Jenn-Air JER8885RAS Electric Stove/Oven unit that I just moved from one house to another. Now that it is plugged in at it's new home, it has an annoying "click-click" sound about every 30 seconds. When I turn the top burners on and they heat up, it stops. I turn them off and when they cool down, it starts back up. I've turned on/off every feature on it to no avail. Anyone have a clue?
Tech007
  • 63 Answers
SOURCE: Hotpoint RB757 Electric Kitchen Range
check you outlet make sure it has 240 volts coming out. it might be your house breaker 1 side bad it is a breaker with 2 points in it 1 side will work and give you 120 volts but the other side is burned out you need both points in contact to give you 240 volts good luck and make sure you use a volt tester you can buy at any hardware
Posted on Aug 29, 2007
SOURCE: stove top burners
It is not the cartridge. It is the ignition switch (sometimes called a cooktop switch) I found mine on ebay. In particular it is a faulty rear switch. Save your money on the cartridge.
Posted on May 29, 2008
SOURCE: electric range
hi,
the burner needs to be replaced, and as far as the oven goes, if you get the same code when you try to use the broiler setting you may need a new control panel. there should be an envelope on the back of the stove with papers in it, that is a tech guide, it should tell you what that code means. depending on the overall condition of the stove it may be better to replace it then fix it.
Posted on Aug 10, 2008
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
philbran
  • 242 Answers
SOURCE: How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Posted on Apr 10, 2009
Electric stove works, oven turns on briefly then shuts down
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
Apr 10, 2014 | Jenn-Air Kitchen Ranges
When turning the oven on an error message appears. Option not available
Check all the wire connections to be sure they are seated and tight.
Nov 27, 2012 | Jenn-Air JER8885RAS Electric Range
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
We have new house and have cold air coming from Jenn-air vent. What can be done to stop this? We had a Jenn-air in our previous home and did not have this trouble
Most stove vents have a diverter plate which prevents air from coming in. When the fan is turned on, this diverter is opened by the air flow and allows the air to flow through. It sounds like this plate is either stuck or was not installed when the ventilation duct was installed.
Oct 16, 2009 | Jenn-Air JED8430 Electric Cooktop
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
73 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
