Question about Dell Dimension 2400 PC Desktop
USB Hi, I have a strange one. I reinstalled the OS on my Dell 2400 all is fine except the USB ports. OS is working, all drivers installed, connection to internet, installed SP3, all the accessories work, the drivers are in and device manager shows no errors. The external drive is working fine. Could all the ports have burned out? rmatheson@wowway.com
  • 1 more comment
  • Robert Matheson Oct 01, 2008
    What is also strange is the USB mouse works, but all the rest of the ports do not. Could it be an issue where 1.0 or a 2.0 and either version conflicting with service pack 3?
    OK, I was wrong it is not the USB port, I think it is the external drive. I have one of the WD solid state drives, I think its called a pony. It appears not to load the drivers to the PC so the computer can recongnize it. It was fine yesterday and I left hooked up when I reinstalled the OS and now it does'nt work. So, there has to be an issue with the drivers of the external, question is why.
  • Robert Matheson Dec 31, 2008
    When you reinstalled the operating system with the pony plugged in then most likely you deleted the partition and OS on the pony. You will have to reinstall the OS and you lost all of your saved work.
    Rob Matheson
    Sergeant:
    Champion:
  • 223 Answers
Its more likely that there could be a loose connection to the motherboard. If not try to attach some ports to the same place on the motherboard and if they also dont work motherboard at fault if they do obviously your old ports are dead for some reason. Good luck.
Posted on Oct 01, 2008
  • Paul Oct 01, 2008
    I know you have probably done this already but run a virus check then a spyware check on the computer just to make sure its nothing else interfering with your drivers. Then check under the device manager that the drivers are installed and if they are or are not use the re-install command there to add the drivers again. I really couldn't tell you why when some drivers are manually added that it all goes wrong. Hope this helps you out.
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
None of 2 usb ports work, drivers fine in device manager tried uninstall ane restart, drivers all install no issue ,, usb still not working
measure the voltage of the usb ports. if it is higher than 5v, than you have a problem. in this case you have to buy a usb hub and connect it through the pcm cia port.
but for your safety reinstall your os first and see if this happeneds again
Jan 27, 2010 | Dell Latitude D600 Notebook
No audio from external speakers dell 2400 computer
hi,
1)Check audio Enabled in bios
2)Check whether audio drivers are installed in device manager if not install audio driver for DIMENSION 2400 from Support.dell.com
3)Check Audio port using Head phones to ensure is audio port is working fine.
4)If Dell speakers, check speakers Manuals from support.dell.com
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Volume control doesn't see the installed audio card or its driver
first of you cheak how many bits xp you use & your drivers driver are how many bits actully xp are two types XP32 bit & XP64 bit & drivers are also two types
Sep 19, 2009 | Dell Dimension 2400 PC Desktop
XP crashed on my Dell latitude D600 laptop. I
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Dell Dimension 2400, mouse stopped working
have you tried using another mouse? if you've re-installed the drivers it maybe thats the problem is corupt system files and a windows reinstall may be required
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
USB ports and resolution failures
Reinstall your drivers you'll find them in your control panel
Apr 11, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 1520
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
What version of vista are you using 32 or 64?
Nov 21, 2008 | Dell Inspiron 2200 Notebook
Dell Dimension 2400
a computer proffesion dosent need a mouse to wok on computer . the windows (logo) botton opens the strt menu . then scroll it with up and down arrows press enter to select . tab to switch between windows and drives . windows key+ e opens my computer . windows +d reduces windows
Dec 23, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
57 people viewed this question
Alun Cox
