Question about Microwave Ovens
My Sharp R-9h91b microwave oven stopped working
Your response to my problem was the most helpful, especially including the Sharp service manual for the microwave. For some reason your response disappeared from my posting so I couldn't reply to you through that thread. However, when I went to the manual you sent I determined that Procedures H, I and J to check the monitor fuse, the magnetron temp fuse, and the thermal cut-out were what I needed to do, and none of those procedures were explained in the manual. There is a reference on the first page of the manual you sent that says it is a supplemental Service Manual to the Base Model Service Manual for R-9H60/9H80 (Refer No. is S5814R9A50DA/). Do you have this manual? Also, did you say in your response that you can get parts for this microwave?
Thank you,
Richardbw0
  • richardbw0 Oct 03, 2008
    Dear MicrowaveSvc,
    Thank you very much for all your very explicit and detailed help and explanations. The service manual and the sketches of what the parts look like, with their exact locations and part numbers explained, and the referral to the parts supplier, all made my repair possible. Also, the second test description about shorting out the bad part and powering on just to see if the lights come on made me more confident that I had the right solution. You are very, very good!
    By the way, some of the other responders were quite discouraging about me even attempting to do the repair if it was anything more than the main fuse.
    Richardbw0
  • Microwave Ovens Master
  • 9,086 Answers
My solution is still visible here: http://www.fixya.com/support/t1083290-sharp_r_9h91b_microwave_oven
But it seems like the site is acting weird or something.
I don't have the other manual, but this repost of my answer covers it all:
Hi, I'm the guy who gave who the service manual link and the long, very detailed answer that covered just about everything that can make a microwave "dead".
You don't actually need the base service manual since this manual has everything you need to locate the parts and the part numbers, as well as the overall schematic.
The magnetron temperature fuse (ref # 1-7, original part # QFS-TA013WRE0) is located in section 3-D of the exploded view on page 25. Physically, it is clipped onto the waveguide above the magnetron and it looks like the right item in the attached drawing.
The oven thermal cutout (TCO) (ref # 1-8, original part # RTHM-A024WRE0) is located in section 2-H of the exploded view on page 25. Physically, it is located on the left side of the chassis near the convection fan assembly and it looks like the left item in the attached drawing.
The best place to order whichever of these you might need is parts is Tritronics. If the part numbers have changed, that will show up on their Web site.
The testing of these parts is simple continuity testing: With your meter on the ohms scale (and oven power unplugged of course) measure the resistance at the terminals of the thermal cutout (TCO). It should read virtually zero. If it reads high / infinity, then it's open and needs to be replaced.
You can also place a jumper or clip lead across the bad (or suspected) device and plug the oven in just long enough to see if it comes to life. Do not cook with the jumper in place, and unplug it right away, avoiding contact with any inside wires or connections.
The schematic on page 4 shows you the "order", if you will, in which the current flows. (Yes, I know it's AC). From the plug, it goes through the oven thermal cutout, then the magnetron temperatuere fuse, then the line fuse.
On that schematic, the very bold black lines show you the essential path required to get power to the board's low voltage transformer, which should result in a lit display assuming the boar dis okay.
If you need more help, please feel free to write me at prototech@usa.net.
If this is not a FixYa, I don't know what is! *grin*
Posted on Oct 01, 2008
Hi I need a user manual for a Sharp R-7E53 (B) M Microwave Combi Oven
use "Sharp R-7E53 (B) manual" in a google search you will find several including the service manual which would not hurt to have.
Oct 11, 2014 | Sharp Microwave Ovens
Digital read out quit working
We'd be happy to help you with free assistance - including part numbers, part sources, and service info - if you'll post a new help request to FixYa including the following:
  • brand
  • full model number
  • detailed symptoms
Jan 22, 2011 | Sharp R-1505 Microwave Oven
Microwave part is not working
There are several possible causes... none of which are user serviceable. Take unit to a shop for repair.
Possible problems include door switch, Magnetron, rectifier, control relay, etc.
Apr 12, 2010 | Sharp R-1872 Convection/Microwave Oven
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
May 26, 2009 | Sharp R-510HW Microwave Oven
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
Sharp R 1480
This is usually a blown high voltage rectifier diode.
We have the service manual and have uploaded it to our site here.
We have critical safety & disassembly info (including a disassembly how-to video) at our site, linked here.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
524 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
