Yellow lite flashing on dell demenison, will not turn green!Clean tower and it work for a wile but it goes back to yellow or amber
  • coolhan Oct 03, 2008
    Thank you ! what can i do to fix this problem?
    Sergeant:
    Champion:
  • 223 Answers
I think that either there is a faulty connection on your power supply or the power supply itself is faulty and needs replacing. Good luck.
Posted on Oct 01, 2008
  • Paul Oct 03, 2008
    Open up the case and the big silver box where the power lead plugs in is called the power supply. I dont know how yours is attached to the case but usually held in by four or more screws. Make a note of what was plugged into where and take the old one out and to a computer store that deals in power supplies. They will be able to give you a matching unit. Just re-fit in the reverse order and it should be problem solved. Good luck.
My dell demention 5150 has like a yellow/amber led light flashe green then goes back. wont even load on my moniter
Your system has failed to POST. It sounds like it may be the PSU. If you decide to open the computer, check if any of the capacitors are leaking or vented. Badbaps.net may be able to help you with this.
Dec 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Don't starts yellow light flasing
If the power button on the tower is flashing Amber, the fault is the power supply. Replace the power supply and they system should work.
If the power supply doesn't resolve then the 2nd most likely failure is the Front IO panel (Circuit card behind the power button)
Nov 22, 2009 | Dell XPS 400 PC Desktop
My computer is beeping at me during startup, and will not go past the load screen.... dell b110
The POWER LED on the front of the tower should be solid Green, If Solid Amber or Flashing Amber, there is either a power or MB problem. On the back of the tower are 4 LEDs the when posting normally are all Green. If YYGG for example, then you have a memory failure. More information can be found at support.dell.com using the no post troubleshooter
Sep 24, 2009 | Dell Dimension™ B110 PC Desktop
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
The screen on my dell 2400 desktop flash but won't come on
Remove the video card from the computer and connect the monitor to the integrated vga port, check if that helps, or else look at the back of the tower or on the front you would find four diagnostic lights, post the status ot them
Feb 05, 2009 | Dell Dimension 2400 PC Desktop
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
