How to connect multiple tvs to dvd player - Televison & Video
  • 98 Answers
Multi-Switch feeder example below for HDMI DVD's
Posted on Oct 01, 2008
I need to run two tvs off one dvd player
If you are using a HDMI output from the player a splitter is available to connect two TVs in to one DVD player. Available everywhere available through Walmart.
Nov 25, 2015 | Televison & Video
How do I get a vhs video to show on my tv?
Not only do you have to hook up the wires correctly, once you have them attached, you must then select the proper input source to view the video. Since TVs have multiple input sources, the remote control allows the user to select which connected input to view.
Sep 18, 2014 | Televison & Video
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Jan 01, 2011 | Televison & Video
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
Mar 29, 2009 | Audio Players & Recorders
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Televison & Video Logo
1,591 people viewed this question
Top Televison & Video Experts
