Question about Canon ZR700 Mini DV Digital Camcorder
Canon ZR700 will not turn on
My canon zr700 will not turn on. I tried to plug it in w/o the battery attached b/c the manual says it will work like that. It did not. The charge light will not come on at all. I used it in may at my son's high school graduation without any problems. I thought it might be the power cord, but it should still work with one of the batteries. I have two batteries, I think at least one of them should work. When I push the button to eject the tape it will not work also.
  • 3 more comments
  • Anonymous Oct 13, 2008
    I'm having the same problem. I had a full battery and i was done filming for a second. I turned it back on and it wouldn't come on. My charge light won't come on either.
    If you find out what's wrong with it tell me please.
  • smkuhn73 Dec 09, 2008
    I am having the same problem. One moment it worked and the next it didn't. I have replaced both batteries and still nothing. The power button want come on at all.
  • Anonymous Dec 11, 2008
    So getting a new battery isn't gonna help?
  • Anonymous Feb 22, 2009
    I'm also having this problem.
  • Anonymous Mar 19, 2009
    My camera will turn off while filming intermittently. I was hoping it was just a battery issue, but no resolution.
SOURCE: Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Posted on Aug 16, 2006
  • 73 Answers
SOURCE: Canon video camer ZR700
THIS SOUNDS LIKE MAYBE A DIRTY HEAD.. OR A LOOSE CONNECTION BETWEEN THE LCD AND DAUGHTER BOARD.. MOST LIKELY A DIRTY HEAD, TRY A CLEANING CASSETTE
Posted on Mar 02, 2008
SOURCE: Canon zr300 ejects tapes
Hi guys,
Thank you very much for this solution posting. Really it worked. I was about to buy another one instead of fixing the problem. Because you know how the pain is, to send it factory and getting it repaired.
Once again Thank you.
Posted on Jun 26, 2008
simplemitch
  • 752 Answers
SOURCE: The tape will not eject.
It's EXTREMELY tricky and runs the risk of causing further damage. I strongly suggest finding a local service center to perform work of that nature.
Posted on Aug 05, 2008
tscmusa
  • 95 Answers
SOURCE: Help! having similar problem with my camcorder?
Sounds like something is jammed in the tape carriage
Call canon and send it in for sevice.There is no tip or trick for carriage jamming issues
Posted on Mar 26, 2010
How do you play what you recorded
It is not possible to play directly on this camera as it is an old model.
You should get a cassette player and put the tape in it and connect it to your TV.
Jan 20, 2013 | Canon ZR700 Mini DV Digital Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Can the canon zr600 use an 8 gb sd memory card
According to Canon's specs, the ZR600 uses DV tapes, not memory cards.
May 20, 2011 | Canon ZR500, ZR600, ZR700, and ZR800...
What is the maximum capacity of the memory card which the zr600 can accomodate?
You can find the information in the manual And you can read this ZR600 manual online page 124 in the bottom few line of words
How to transfer mini dv records to pc?
CONNECT THE CAMERA VIA THE DV -4 PIN CABLE TO YOUR PC ON THE FIRE WIRE CARD -
INSTALL THE CANON DRIVERS FROM CANON WEBSITE
USE A VIDEO SOFTWARE LIKE ULEAD OR WINDOWS MOVIE MAKER
MAKE YOUR CONNCECTION ON THE PLAY MODE AND PLAY THE MINI DV
BEFORE THE PREVIOUS QUOTE MAKE THE AV-DV OPTION ON IN YOUR CAMERA SETTINGS
ALL THE BEST
Oct 10, 2009 | Canon ZR700 Mini DV Digital Camcorder
Grey Bars appear on video playback
The monitor you view while recording does not read from the tape where the problem is located, that's why you are not seeing them during recording.
Since they are not visible while recording, the video section is healthy, only the recording is faulty and it is unlikely you can do anything at home to correct it.
This may be a common problem and perhaps Canon is familiar with it.
I recommend you call their service line directly:
email: https://www.usa.canon.com/consumer/controller?act=SupportMailerAct&fcategoryid=227&modelid=12812
Phone: In the US: 1 (800) 828-4040
May 14, 2008 | Canon ZR700 Mini DV Digital Camcorder
Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Mar 25, 2008 | Canon ZR700 Mini DV Digital Camcorder
Oct 14, 2007 | Canon ZR85 Mini DV Digital Camcorder
CanonZR700 playback trouble
camera it's showing nothing on the computer.
Jun 12, 2007 | Canon ZR700 Mini DV Digital Camcorder
Canon ZR700 Mini DV Digital Camcorder Logo
161 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
