I have a 10-year old JVC 32" television. It shuts off frequently, and I have to unplug it for at least a few minutes and then plug it back in for it to turn back on. It used to do this once every few weeks, but now it happens several times a day when it is being used.
  • fearthemunky Oct 01, 2008
    That is a 32 inch screen.
    AV-32950
    Scholar:
  • 142 Answers
Please re-enter your model number. It should read AV-32....
barneyluc
Posted on Oct 01, 2008
Dynex tv 2 years old shuts off while watching tv
Ensure that all connections are secured. Try power-cycling the TV by powering it off, unplugging it & leave it unplugged for a minute, and then plugging it back in and turning it back on. If you still experience issues, I would recommend bringing it into your local store for repair assistance. Keep in mind, if it requires repair, it may not be cost effective, and therefore, you may want to consider purchasing a replacement TV.
Nov 06, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Flashing timer led
There is no reset button like in the old days. You can reset the microprocessor to it's default state by unplugging the set, let it stay unplugged for 10 or more minutes. Plug the set back and it will reset itself.
You might lose stored channels and settings but they will all be reset to the manufacturers specs. This is true for anything that has a microprocessor (computer) in it.
Apr 19, 2010 | JVC AV-32D502 32" TV
The TV shuts off automatically and the Timer On button on the front of the TV flashes. The TV will not start again, either manually on the TV or with the remote. If we unplug the TV, leave it off for a few...
sound like timer setting on . you need to go to setup menu the timer set it off, if not , you need to check power supply unit, high value capacitor if under reading replace it. good luck!
Jan 27, 2010 | JVC AV-32230 32" TV
TV shuts itself off. ON/OFF switch no longer works.
If your sure the switch is broken, you can remove the switch and directly attach the wires and plug and unplug to turn it off and on. But it sound like that if the switch is broken you have a slight connection and with an ajar it will turn off and on by itself. The good thing to do would be to purchase a push button switch at your local electronics store for between $1.25 to $10.00 depending on what one you would like to have.
if it is remote control you could have what they call a sliver on the circut board to that can cause this to make the tv turn off and on. Best way to check this is to take the remote batteries out and see if the tv still turns off and on. If so replace the switch.
May 07, 2009 | JVC Televison & Video
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Get get any responce on my JVC AV27530 27" TV
,,always unplug the set from AC,leave off a few minutes,,then re-plug back in,,that resets the micro--also,it could be the volume up button stuck-that would kill the other keys from working--you could try with a tooth pick to pull VOL UP back----THIS IS DANGEROUS --SHOCK HAZZARD!!! if someone is technically incline,with the back of the tv off,,turn set on and unplug the keyboard plug from the main circuit board while the set is playing--then use the remote and see if the fuctions returned-THIS IS DANGEROUS-SHOCK HAZARD---I REPEAT -DANGEROUS!!!! PLEASE BE CARFULL,if that cures the problem-you have a bad keyboard-you can just leave it unplugged and use the remote----JUST BE CARFULLLLLLL
Feb 11, 2008 | JVC AV-27530 27" TV
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
