Monitors
Problem for Monitors
Generic problem for all Monitors
LCD Monitor is black... blowing transistors
By bmelnyk on Oct 01, 2008
Product is a Benq FP931 19" Monitor
LCD power light is on and green (getting signal from the video card) but the screen is black. I can see my desktop when I shine a light onto it...
I took the monitor apart and nocitced 5 blown capacitors.. This leads me to believe that the backlights may be ok.. but will for sure when the capacitors are replaced.....
I replaced the capacitors and plugged the monitor back in. Immediatly one of the new capacitors popped, smoked and was leaking some stuff.... so Im sure that i need to test some fuses and transistors.. problem is, Im not exaclty sure which is for what and how to test properly.
Thanks for any help...
Comments:
Oct 02, 2008
- ok I may have installed it backwards.. honestly im not sure exactly what I am doing.. how can I tell which way is not backwards.. the caps i took out were 25volt 1000uf.... i made sure they were the exact same..
thanks for the response
Solution #1
posted on Oct 02, 2008
Not Rated)
noone
Rank: Guru
Rating: 85%, 200 votes
Bulging or "blown" electrolytic capacitors are a common problem with LCD monitors. If you replaced them with correct parts (voltage rating) then one of two situations comes to mind:
1. Electrolytic caps are polarized, if you install them backwards they will blow quickly.
2. The voltage the circuit provides exceeds the rating of the cap. A 5 volt cap in a 12 volt circuit will blow quickly. The voltage regulation circuit may not be working.
Monitor Mike
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
Screen message reads "no video input",blue scart is connected at both ends,what have i... (More)
Answer
I have Samsung 713N monitor with "Not Optimum Mode" error on bootup. I have scoured the... (More)
Answer
How do u raise the monitor stand higher? Mine is the 2007WFPb Dell monitor stand. I can't get it... (More)
Answer
how do i change the input to hdmi
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
