Computers & Internet Logo
A
Anonymous Posted on Dec 03, 2011
How do I change font (to readable size) when printing out from internet when there is no choice indicated
Windows Vista Premium Inspiron 530S
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Dec 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
129
Points
IF YOU RIGHT CLICK YOUR MOUSE YOU CAN SELECT COPY ALL THEN PAST INTO MICROSOFT WORD THEN CHANGE THE FONT SIZE OR YOU CAN SELECT PRINT CHANGE PRINTER TO ADOBE CONVERT TO A PDF THEN PRINT
  • Anonymous Dec 03, 2011
    When I right-click my mouse I don't see "copy all"
    CTRL+C WILL WORK TOO.
How do I change the font on my computer?
Type Change Window Colors and Metrics into your start menu, when the widow comes up your going to want to select icon as the item type, or any other you wish to change. In order to adjust the font face change the value selected, may also need to change the font size to make your font of choice readable. Make sure you hit Apply, you may have to do this a number of times in order to get the fonts (and size) you want. This will affect the fonts in your OS (Windows), things like icons, right-click menus, Start Menu.... However if you want to change the size inside of other programs you will need to get inside of their individual settings.
Hope this helps.
Aug 22, 2013 • Plumbing
How do i bold print
Bold underlined itallics fontsizes and colours
Type <b> before the writing that you want bold.
End the bold text, type </b> after the part that you want in bold to go back to normal.
Type <i> or <u>, to write in italics, or underline.
Type <center> to center a selected area. When finished, you will need to type</center>
Type <font color="colorcode"> and end it with </font>,to write with different colored fonts.
Type <font fontsize="size">to change the size of the font you would like to use.
hope this helps
3helpful
How do I make my text size larger?
This is for windows vista:
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Adjust font size (DPI). 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
Source
How do you change fontz size on dell computer
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
2answers
Word are too small to see on my computer
You can change size of fonts of your computer with the help of styler. You can download styler from http://www.crystalxp.net/galerie/en.id.551-styler-1-401.html easily and change the size. To change the size you press to the style tab .There are also three tabs: Folder,color and fonts. choose the font tab and increase the size of fonts. Best of luck.
4helpful
How to increase the font size when printing?
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Lexmark 5470.
The printer only prints dots sent down by the computer. It has no concept of a font or letters at all. You'll have to change a setting on your email program. Or cut and paste the text you want to print into a word processor where you know how to change the font size.
Steve
Printer font size
Click on Format.
Click on Font.
2answers
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
