When turn on monitor start button goes off press again it works, run ok after been on
  • old hall Oct 01, 2008
    simlar broblem with modem think the problem lies within my belkin socket ext,
    thank you.
    Sergeant:
    Champion:
  • 223 Answers
I think the problem is dry solder joints somewhere on the monitor. If can check this for yourself otherwise find a competant technician. This could also be caused by a faulty diode or capacitor on the power supply board. Hope this helps.
Posted on Oct 01, 2008
I just installed a MAG 17 incuh flatscreen monitor to my Dell Dimension 3000. When I turn the PC on, the monitor disploays everything on the desktop,but then goes black. If I turn the monitor on and off,...
I think that you have chosen some settings that are not compatible on it ..resolution too big and probably the refresh rate high ..
first from the monitor settings ..press the auto-settings button ..and let it make the proper choice ..after that ..to eliminate any settings in the video card that might affect it ..boot your computer in safe mode..and remove the video card driver from control panel ...add /remove programs ...and after that run it again from the disk or ..from teh support site if you do not have the disk ..
If you only have the on board driver..and you do not have a disk ..run it from the drivers of the motherboard disk ..This will reset the odd choices on the video card ..and make it work ..to open in safe mode..press F12 on start ..and choose safe mode..(for some computers the button is F9 or F8 )Usually the button is specified when it boots up ..
But ..for to be sure that this is the cause...you have to hear to computer running ..and only the display to be black ...otherwise can be a physical fault..
Jan 22, 2011 | Mag Innovision LT776s 17" LCD Monitor
Hello I have a problem with my HP Pavillion m9277. When I switch the computer on it goes ok for about 5-10 seconds, cuts out for 5-10 seconds and then starts up again, but there is also nothing happening...
Hi Friend, As you have mentioned that your system goes off after 5-10 seconds and turns on again. I would recommend you to please unplug all the cables from the desktop and press and hold the power button of the system for 30 seconds, release it after 30 seconds and make the connections again.
Start your system again and check if your issue is fixed or not.
Also I would like you to check after turning on the system do you get any beeps from the system after which it goes off
Dec 08, 2010 | Computers & Internet
Turn off sound when heartrate drops
On the screen just prior to work-out mode:
1. Select Settings using the right buttons and the OK button.
2. Select HR Alarm.
3. Select Off.
4. Press the OK button.
5. Press OK again to start exercise.
The same can be done during exercise by hold the OK button down to get to the menu. Very convenient when you use the alarm sometimes and have left it on.
Jul 01, 2010 | Polar F11 Heart Rate Monitor
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
When turn on BIOS wouldn't load until i press restart
you are having problem with the connector i;e power button try at some good repairing shop
May 26, 2009 | Intel D945GNT Motherboard
How do I turn off the change oil light on a 1994 corvette
1. Turn the key to “Run,” but don’t start
2. Press “ENG MET” on the Trip
the engine.
Monitor. Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The
“CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the
“CHANGE OIL” light stops flashing
and goes out. This should take about
ten seconds.
When the light goes out, the monitoirs
reset. If the monitor doesn’tr eset, turn the
ignition off, then try again.
Nov 18, 2008 | 1994 Chevrolet Corvette
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Monitor problem
1 check connector from monitor to computer. 2 video card in computer if any for loose or defective. 3 loose contact in monitor 4 problem in smps power supplyinside monitor. 5 if it is ok check horizontal section in monitor. 6 crt base or any connector loose.
Sep 27, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
