Question about Bose Wave Radio
Bose Wave radio
When powered on by plugging in power cord, display is bright, it runs "seeking", then display dims and no buttons work
  • 12 more comments
  • Lee Wilson Oct 01, 2008
    I should add that the display blinks after "seek" is finished. No sound, no buttons work - just the blinking hour display. Thanks
    Also - the first suggestion didn't work - but thank you
    tried that already - thanks
    no change after following the 2 suggested solutions - thanks
    Have tried removing batteries, letting it discharge overnight - so far - no change
    so what does that mean - replace cord? replace something in the radio? thanks
    as I said at first - no buttons work -
    naguu - I downloaded manual - no info on rest to default settings - thanks
  • Lee Wilson Oct 02, 2008
    no luck with any of the suggestions?? any others
    no cd player in this unit
    yes
  • Lee Wilson Oct 03, 2008
    to restate the problem - radio turns on, goes into seek mode, then reverts to flashing time. No buttons work - no sound. Various power points tried, no luck. Thanks to all for suggestions - any others?
    yes
  • Lee Wilson Oct 11, 2008
    none of the buttons seem to work - doing a system reset is therefore impossible
  • 1,512 Answers
Hi, with the indulgence of others and your continuing patience, you can get the user manual here.
  1. Have you been able to set the clock by depressing the SET button and the TUNING button down together?
  2. Is the power lead hanging down or rolled up. It acts as an aerial for FM reception.
  3. When you powered it down overnight, did you remove the backup batteries also.
Also check that the remote control is not sending oddball signals to the radio. Put it in a drawer and run the start up test again. If you have no button operation AT ALL and abnormal start up events occurring and are confident that you have been able to reset the unit effectively, then it is safe to assume the unit may have an internal electronic fault and require some attention.Other than that, sounds like gremlins have
Posted on Oct 08, 2008
  • Graeme Ross
    Graeme Ross Oct 08, 2008
    taken over the radio and it is time for a probably too expensive to be economical repair, or to just replace the replace the unit. Buy a Sony :)
    Sergeant:
    Champion:
  • 298 Answers
You need to system reset, if you wish to do so i can go to page 21 of your user manual. if you do not have it here it is. click here thanks and hope this works out for you.
Posted on Oct 03, 2008
  • 1,183 Answers
The tuner inside needs to be checked for problems. Contact the Bose service centre
1-800-367-4008,
Monday - Friday: 8:30 AM - 9:00 PM ET
Saturday: 9:00 AM - 5:00 PM ET
There very few people on forums that can service bose equipment,its best to get the authorised tech do the job.
Thanks
proton
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Usually seeking is used for CD's, it is trying to read what type of CD it is 1st ( CD, CD-R), you did not mention if this model has a CD player, there may be a disk stuck inside the unit and it can't read it.
In this case the most likely thing is to keep turning it on & off and hitting the eject button ( has happened to me on a different model CD player) until it spits it out.
Another thing to try is to hold down a button (eject, AM, FM, channel up or down even 2 at the same time) as you turn it on to override that "seeking" mode.
Good luck, hope this helps.
Posted on Oct 02, 2008
  • CheckitRight
    CheckitRight Oct 02, 2008
    OK, so this means it is looking for a station, did you try the second solution (holding down a different button as you plug it in?)
    Tnx
    Sergeant:
  • 320 Answers
Please reset the device to default settings... Go through manual.. To download the manual please click on the below link or copy the URL and paste it in your web browser..
http://products.bose.com/pdf/customer_service/owners/wrv2_guide.pdf
Hopefully it should fix the problem... Please let me know..
Thank you......
Posted on Oct 01, 2008
  • Bose Master
  • 19,396 Answers
Sometimes to activate the radio mode you have to press the AM/FM button.
Try pressing the AM/FM button to activate the radio.
Check that the remote is working, pull out remote battery and put it back.
Try operating the radio from buttons and see if it works.
  • Ginko
    Ginko Oct 01, 2008
    Here is the manual:
    The Bose Wave Radio
  • Ginko
    Ginko Oct 01, 2008
    Did the radio workesd before?
    Was it in same location, or had been moved?
    What happened before having this problem?
    Brigadier General:
  • 6,966 Answers
Your description of "...seeking...:" could indicate:
  • if it is on the AM/FM/tuner/radio mode, then it could not pull in the radio stations;
  • if it is on CD mode, then it could not read the CD.
Your added post of "...display dims and no buttons work..." further may mean that:
  • no station, no disc read, unit shuts down;
  • it is in standby mode hence no buttons will work not until "woken" up.
Suggested actions could include:
  • visually inspect the back where the antenna input/terminals are and check for any loose/detached wiring;
  • check the 9volts battery underneath, not really necessary but it also powers the memory/logic circuitry;
  • if I remember right, there is an FM antenna that is built in to the AC cord, you could try uncoiling or straightening said cord,
  • relocating the radio or repositioning/reorienting could also help;
  • if it were the CD, try using a CD lens cleaner (those used in DVD players and PC CD ROM.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 01, 2008
    Hi again,
    If all else fail, it may require opening up. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
    Genius:
  • 1,124 Answers
Bad power supply
  • 3,037 Answers
Try getting it totally discharged, if you have backup batteries in it remove them, let it sit for about 20 minutes and then plug it in and see if it will work.
    Guru:
  • 1,894 Answers
This is a power problem.
leave the unit unplugged for one night and then try switching ON
  • dewan nafees ahmed Oct 01, 2008
    ok. did you try a different power point?
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
386 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
