Question about Samsung HLM507W 50" Rear Projection HDTV
Samsung dlp tv no picture
I know about the lamp or balast thig just want to see if there is a way to test the ballast before i buy a lamp. im verry handy with a volt meter
  • 6,784 Answers
Sure, you can test by Use the screwdriver and remove the protective cover that conceals the ballast.
Observe the ballast before proceeding. If oil is leaking from the ballast, stop here and remove the ballast. Leaking oil indicates that the ballast is damaged beyond any doubt as the internal seal has been ruptured by excessive heat.
Test the high voltage side for continuity between the wires going to the ballast tombstones. There will be either one or two wires going to each tombstone fixture. Regardless of the number of wires, the colors will be the following: Blue or yellow are the power wires and white is the common or neutral wire. this could differ in many models.
Turn the Volt Ohmmeter to "ohms" and touch the ends of the two probes together. The meter should show continuity or a direct short. Touch the probes of the meter to one of the white wires and one of the colored, blue or yellow, or any wires that comes from the ballast. This should show a short or continuous circuit. If it does not, the ballast is bad and should be replaced.
Posted on Sep 06, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Replaced the balast, tv not longer turns on and off but now it has a kind of pulsing picture. Am I looking at a new bulb? a new color wheel ? or some other surprise that I haven't heard about?
Lamp is possible especially if the ballast was bad--it powers the lamp.
Color wheel will usually display some issues--high pitched whine or fan like noise---with the lamp removed look where it faces--color wheel is there--any broken or missing pieces and it is the problem---
The wheel is directly connected to the set---set will detect if wheel not moving or moving too slow etc and almost instantly turn the lamp OFF.
Apr 30, 2012 | Samsung HL-67A510 67" DLP HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
DLP TV Samsung HLP4663W
Your problem could be your lamp is not seeted all the way in. Take you lamp out and put it back in. Or it could be you ballast that lights you lamp is bad. You may need a new ballast.
Mar 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
696 people viewed this question
Henry  Thomas
Henry Thomas
