Question about Maytag Washing Machines
My maytag neptune washer model mah5500b won't spin the tub on wash or rinse,but the water will drain from the tub on rinse cycle thanks
    Scholar:
  • 142 Answers
Your lid switch is bad.
barneyluc
Posted on Oct 01, 2008
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Water trapped below the barrel
It is normal to have residual water in the drain lines and drain pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
Maytag Centennial: Not starting, maybe lid lock issue? How to install new magnetic lid latch? then is replacing lid lock next or could it be something entirely different? Help, please, and THANK YOU! I have a Maytag Centennial washer MVWC450XW3 that quit working last week. In hindsight, I could see that there had been a history of "stuff" going on with the washer, all around the lid lock;i.e. - last time it worked I had to select a couple of different cycles before it finally started. SO Far, I have tried to get the diagnostic codes but failed a bit at that. I THINK that I was getting an F5E1 error. I was however at least able to access the diagnostic menu, and notice TWO things: No matter what, the Lid Locked LED never comes on, ever. Next thing I notice is when I do a short cycle diagnostically, it never agitates or spins. It fills various temp water, does not agitate, then it seems to suck the water back out. IN the end, I ordered just the magnetic part of the lid lock (the part that is actually on the lid) because I could see mine was rusted all the way away, but am not too sure how to put it on. Therefore I just put it in the slot where it would go if I had installed it. Incidentally II asked my ma if she had noticed anything going on with the washer and she said No at first but then with prompting (she's 81) allowed that she had indeed noticed something wrong with the lid shutting so she had cleaned out that "little hole"{ very well and oiled it to make sure it was working. So again my two main questions are: How to install the lid latch, do I need to take out all of the screws around the glass? and Should I next move on to buying a lid lock part or could it be something entirely different?
Mar 21, 2017 | Maytag Washing Machines
Washing Machines Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
