Question about Mitsubishi VS-50703 50" Rear Projection Television
Lines top and bottom of screen
TV has always been great. I now have numeropus small lines at the top and bottom of my screen. Plus we are now getting blue shadows around text. I have heard it needs interior cleaning.
  • tberrry Oct 06, 2008
    Other TV's in the house have appeared to be fine. I can verify this connection.
    The cable and connection are fine..
    Brigadier General:
  • 6,966 Answers
Pls confirm the exact model number of your TV. Additionally, it would facilitate if you could also determine a Chassis Number if any.
If it were a conventional TV, then initial suspect would be a capacitor at the vertical section is about to fail. This is relatively an easy and cheap repair. Nonetheless, this of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. Or consider the alternatives as proposed by the other experts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 20, 2008
  • 507 Answers
Could be
Caps in the vert circuit and then vert output IC la7838 and 100uf@35v
Vertical output and associated capacitors and resistors
  • 905 Answers
This is the conversion IC , it is most common in all projection TV's , the IC is an STK type it will correct the problem
the IC is only about $30-$40
but to have a tech come and replace that IC is about $300 or more
electech
  • jason Oct 20, 2008
    also there will be some resistors to replace
    President:
  • 2,712 Answers
This is a complex repair and the exact cause cannot be determined with conducting tests and a manual inspection. If you have no experience with TV electronics or repairs, I would never recommend a DIY. Trying a DIY could, infact, actually make things worse in the long run.
In my honest opinion, it is better to send the TV to Mitsubishi and get it serviced. They will stand behind their repairs. If you feel the cost is unjustified, then best bet is to purchase a new set. In this case, you can attempt a DIY, if you feel inclined to do so..
Cheers!
Posted on Oct 06, 2008
  • 52 Answers
I don´t think so. You have a technical problem. Is your cable operator working ok?
    Genius:
  • 1,847 Answers
The PIP board is small and square and stands straight up on the main board. It plugs into a socket. It also has a ground wire that has to be unsoldered to remove it from the machine. It is located essentially in the middle of the main board near the rear of the set. Sorry I can't describe it any better. Go to http:\\www.tritronicsinc.com or call 1-800-638-3328 for parts. Thank you!!
The tv was on and she came running with a cup if water and fell she splashed the water on the the tv and a gray line appeared on it almost instantly please help the tv is only 6 months old
Ill bet the grey line is on the left going from top to bottom ? The screens mains power is located just below the lip of the TVs base screen line this would have shorted meaning a new screen costing as much as a new tv :( always remember when cleaning the screen never spay it directly either as this has caused the same issue many times 10_3_2013_2_30_25_am.png
Aug 22, 2013 | Televison & Video
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
May 23, 2011 | Panasonic Viera TX-32LX77 LCD TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony kp53hs30 screen is curved at top/bottom when in widescreen
on the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
