Question about Radio Shack Pro-95 Handheld Scanner
Completely locked up
When you turn on 0.234.6789 All Channels Locked Out! displays.
Nothing works, tried to reset, and reinitialize. No matter what you do this is all you see.
  • marcos4903 Nov 06, 2008
    when i turn on the scanner the number zero appears and it does nothing but blinks. it would not scan after i had already program it........
  • 27 Answers
Are you pressing the "SCAN" button?
Try pressing the "search" button on the bottom left of the key board. If you want to use the "SCAN" button you need to program frequencies into the banks.
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightend paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
This may be a little overkill but it doesn't hurt.
Hope this helps.
Posted on Aug 01, 2009
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
Attempted to adjust the color display on my brand new Cobra 29 LX and now the display shows only the number 88 and some rows of digital blocks-the CB display is completely locked up and nothing i've...
The display on this radio uses firmware. I fear there may be a glitch in it. Maybe it was flashed wrong. If you hit the dim button, and it doesn't go back to normal, something is not write with the firmware.
There is not much out there yet about tweaking this. You will probably have to send it to cobra. It should still be under warranty.
Jun 18, 2011 | Cobra Radio Communications
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
My scanner was working fine until I held down the lock button. It didn't actually turn on the key lock (the key symbol didn't come up on the display) but now none of the keys respond to presses. I tried...
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
Aug 14, 2010 | Radio Shack Pro-82 Scanner
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
Device selection button locks up TV and after a few minutes turns TV off. Device selection does not function
with the remote press menu2 4 7 0 enter this should reinitialize set when it has reinitialized push reset button on front panel this should cure it. You will have to reprogram your channels and net command though.
Jul 30, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Jun 18, 2008 | Apex Digital ADV3800 DVD Player/VCR
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Radio Shack Pro-95 Handheld Scanner Logo
238 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
