Washer Hello , I have a top load washer (110.2692 ) its about two years old. My leak detector went off . When I pulled washer out i did find water leaking from bottom. More disturbing was I also found a oil / watery mix. Or maybe it was a greasy / watery mix. anyway that is what I found on the floor and touching (what I call the drive shaft) found it there. Being stubborn, I cleaned everything up and threw in a small load.I put paper towels under unit and turned it on. After cycle was done I pulled out paper towels and found a small amount of water. I was just curious. I know it must be something serious , because of the oil / grease thing. Any ideas ? Thanks , Tom
    Novelist:
    Champion:
  • 261 Answers
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Posted on Oct 02, 2008
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite washer
Okay...what you are talking about is a honey colored oil, right? The gearcase (transmission) is filled with this oil. Sometimes the gearcases are prone to leaks. There is a small breatehr hole onthe top of the gearcase housing that oil will sometimes weep out of when it expands. This could be a potentially serious problem, as a leaky gearcase COULD mean it is beginning to fail. But...not always. This is kind of a gray area when it comes to this model washer. As leaking oil is generally considered a bad thing, the gearcase could actually run for quite a long time and experience no failures, or further leaks. I would keep the oil cleaned up and run the washer as you normally would. If the leaking becomes progressively worse, the tub begins to spin slower than usual, requires assistance to spin, clothes aren't spinning dry enough, or if the gearcase starts to exhibit loud noises, stop using the washer and plan on needing a replacement gearcase. They generally run about $150 and can easily be installed by the DIYer. If you wish to pursue that as an option sometime, just let me know and I can provide you with the steps required to do so. At this point, monitor what you have and let me know how much the gearcase is leaking.
As far as the water leaking is concerned...you need to determine WHERE it is coming from. If it is leaking in the center under the wash tub in the location of the gearcase, the tub seal probably needs replaced, or you may have a crack in the tub somewhere. If the washer is leaking near the front, this is generally a sign of a leaking water pump, or associated hoses. Check to make sure the hoses are clamped snug. If the washer is leaking in the back somewhere, I would suspect a leaking water inlet hose, or drain hose. The best way to make the determination is to place a sheet of cardboard under the washer when it is empty. Do a load of wash and pull the cardboard out when done. Note where the leak patterns are and get back to me. I need to know where the water is coming from before I can give you a correct assessment. I hope this helps guide you in the right direction.
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Mar 14, 2009 | KitchenAid KAWS700L Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Oct 01, 2008 | Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Dec 15, 2007 | GE WCXR1070A
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
