Question about Archos AV400 Digital Media Player
Archos AV400 Power Adapter
Hi I bought my Archos AV400 (100GB) back in 2005. I lost my AC/DC Adapter (Charger). I've looked everywhere and cannot find a replacement. The nearest I've got to is a charger from Jaycar 5V 1AMP for $18 Australian. Would this suffice?
Thanks
mahroofisonfire@hotmail.co.uk
Wallwart is model # trc-05-1600 made by group west I have one, though I cant let it go... BUT may battery is dead and i have to unscrew? the back to replace it. Got any tips for me?
Posted on Dec 06, 2008
Lost my charger need to charge from internet
Laptop chargers also be called as power adapter, AC adapter or DC adapterCheap Laptop Charger online for UK For US: laptop AC adapter & laptop DC adapter You can use universal laptop AC adapter too.
Apr 29, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
What kinda of charger can i use for an archos av400 can i get one at radioshack?
Hi I have the 605wifi so would think they are the same, it says
5volts dc the attatched plug (cylindrical) has + pos inside,
-neg is on the outside.
I would also make sure its a regulated output.
Hope this helps
Dec 12, 2008 | Archos AV400 Digital Media Player
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
I have a archos av400 and it is coming on read access error can't read from hard drive please help
If it is a av400 series
plug it into the computer and attempt to format it.
If it fails its a very high probability the hard drive has failed.
there is a slight possibility its the ribbon cable that connects the drive to the main board or the controller in the archos so I would check the drive after removal and prior to buying a new one.
this can be done in a usb caddy or with a 3.5" to 2.5" converter (about $5 on ebay) letting you put the drive in a PC for testing.
If its above 40gb any 2.5" laptop drive upto 100gb can be fitted.
If its a 20gb you need a single platter 1.8" ata drive
any further questions just ask
Apr 27, 2008 | Archos AV400 Digital Media Player
It won't start. my Archos AV400
Probably a bad connection from the drop, or one of the ribbons has gotten loose. The only way to tell, is to open up the player and examine it and look for damage.
Sep 05, 2007 | Archos AV400 Digital Media Player
Archos Gmini220 Power Supply?
The charger which came with my Gmini 220 is 5V DC, 1.6A. It measures about 5.18V. The +5V is applied to the normally unused pin on the USB connector. The charger's plug is built so you and plug the charger into the Gmini and then plug the USB cable into the charger.
Aug 01, 2007 | Archos Gmini 220 MP3 Player
My Unit Will Not Power Up
Not sure if this is a solution for you. I had a problem with the DC power input jack on the player going bad. The batteries would no longer charge. I bought an extra battery and a USB charger from ebay. Now I'm good for two battery cycles and it works again. Although it will never charge it's own batteries or work off of AC power it does still work.
Dec 21, 2006 | Archos AV 700 160-Hours Video Recorder
Archos AV400 Digital Media Player Logo
380 people viewed this question
Top Archos Audio Players & Recorders Experts
Justin
Justin
George Hoggarth
Level 1 Expert
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
