Question about Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115
"high pump" (jets) shutoff
I have air buttons controlling my jets. When I hit the "jets" air button, the jets only stay on for a few seconds and then shut off. The pump keeps running on lo speed. I can't tell if I have an air button problem or a pump problem. Pump was recently replaced. How can I troubleshoot this problem?
  • 547 Answers
Look at circit board see if it s burnt replace
Posted on Feb 12, 2009
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
After shutting down it will flare up for a few seconds.
You have a dusty jet .When the dust blocks and restarts the flow the sudden pressure causes flame .Service your nozzles or jets and check for any leakages after the jet.
Dec 12, 2013 | Dyna-Glo RMC-8001SS Heater
Jets won't stay running
When you push the air button down it sends a column of air to the air switch located in the motor. When there is not enough air sent by the air button on the top of the tub it will not make the air switch "latch" in the closed position and means you need a new air button.
In your case the air button is sending enough "air" however when the air switch is not "latching" in the closed position that means the air switch is bad and needs to be replaced.
Most air switch's can be replaced with a TBS-310
US Parts Center
Apr 19, 2013 | Jacuzzi NOVA 5 WHIRLPOOL WITH INTEGRAL...
Jets in whirlpool tub not working
If its on a GFCI circuit reset switch.
Air button activation - check for loose air tube connections or bad air button.
Electronic control - contact a spa technician for diagnostics.
If the error is not electricity to the pump or the button(s) controlling the pump - it is likely a bad pump.
Jan 17, 2012 | Whirlpool Home
I have a jetted tub that has not been used in years, but still worked until recently. When I went to use it you could push the button all the way in with no response from the motor. So just wondering if...
the button is an air switch, check the simple things first. your tub is connected to a gfi plug or breaker, try reseting the breaker first.next is the air hose from the button to the pump connected,is it split or have a hole in it. with the access door removed pump the button and listen for an air leak, if so remove hose just by pulling on it, most hardware stores carry the same hose and sell it by the foot.
Oct 24, 2010 | Home
Turned of car, will not start it turns over, but doesn't seem to be getting any fuel
Try A SMALL SHOT Of Starting Fluid Sprayed into the Snorkel
Intake @ Air filter. If it Starts and Does NOT Run After Burning Starting Fluid the Fuel Pump Has Failed. (My Personal Hunch) is (FUEL PUMP FAILURE) BE SURE TO ELIMINATE THE INERCIA SWITCH< it is a fuel shut off switch >>>>> WARNING: Do not reset the inertia switch button if you see or smell fuel.
  1. Turn ignition switch to OFF.
  2. Check for leaking fuel in the engine compartment, fuel lines and fuel tank.
  3. If no fuel is apparent, reset the inertia fuel shutoff switch by pushing the reset button on top of switch.
  4. Turn ignition switch to START for a few seconds, then to OFF.
  5. Again, check for leaking fuel.
LOCATION
  1. Open luggage compartment door.
  2. Remove two screws retaining inertia fuel shutoff switch.
  3. Disconnect wiring harness connector from inertia fuel shutoff switch and remove inertia fuel shutoff switch.
  4. To install, reverse removal procedure.
Aug 17, 2010 | 1996 Mercury Cougar XR7
What is the fuel symbol for in the pass. side floorboard of my 01 focus
FUEL PUMP SHUT-OFF SWITCH
After a collision, if the engine cranks but does not start, the fuel pump shutoff switch may have been activated. The shutoff switch is a device intended to stop the electric fuel pump when your vehicle has been involved in a substantial jolt.
1. Turn the ignition to the OFF position.
2. Check the fuel system for leaks.
3. If no fuel leak is apparent, remove the cover plug in the trim and reset the fuel pump shutoff switch by pushing in the button on the switch.
4. Turn the ignition to the ON/RUN position. Pause for a few seconds and return the key to the OFF position.
5. Make a further check for leaks in the fuel system.
The fuel pump shutoff switch is located in the passenger's foot well, behind the kick panel. The reset button is accessible through the recess in the kick panel.
Replace the cover plug in trim after reset procedure.
THis and other details can find in the Owners Manual.
Hope helps (remember rated and comment this).
Jul 22, 2010 | 2001 Ford Focus
I have a 91 buick park ave ultra. when you hit the auto button the air cond will not come on. however if you disc the hot lead at the batt for 15+ seconds, then reattach, then turn the car on, then hit the...
yes ther is but usally this is a warning that there is something wrong ,need to have ac gauges put on it to check to see if a blockage in system or if the high is running to high, could be as simple as a cooling fan not doing its job or low on freon it doesnt take a lot for the ac control head to detect anything out of range and shut down to prevent damage
Jun 30, 2009 | 1992 Buick Park Avenue
Jacuzzi nova 532 motor run's but won't stay running
If it has the little oval off/on button, it sounds like the control box or off/on button is bad. If you have access to the pump assembly, follow the pump power cord to the little black box (zip tied to a tube up high), this black box has a small cable that goes to the off/on button. unplug the pump from the box and plug the pump into the power outlet. it should run continuously. If it runs, you need a new control box or /offon button. Buy the off/on button first, as this button is prone to water getting into it, and costs less than the control box.
Mar 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Waterway 1 Hp 115 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 1.5" Plumbing # S10115 Logo
317 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
