Question about Refrigerators
Freezer won't stop running - Refrigerators
  • Anonymous May 21, 2009
    freezer won't stop running
  • 750 Answers
Hello, dodgedust
Welcome to fixya.
You said, Your freezer will not stop running.
What is the brand freezer and the model number?
How old is the freezer?
Freezers are supposed to go on and off as needed to keep the temperature at a consistent .
We call this cycling on and off.
The problem sounds like a malfunctioning thermostat.
Left like this it will eventually burn out the compressor!
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your freezer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new rfreezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old.
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Waiting for your information!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 30, 2008
Lights on fridge freezer won't stop flashing
Make sure light bulb is screwed in pretty snug
Feb 24, 2013 | Freezers
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
The compressor won't stop running
Sounds like the contacs on thermostat, has welded togher. Compressor will run till it starts pumping liquid frezon, then over heats ,then shuts down till it cools off , and starts all over again
replace thermostat..
Jan 13, 2013 | Refrigerators
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Kenmore Elite 106.53609202 won't get cold (refrigerator or freezer)
When you say it's running, do you mean the fan in the freezer or the compressor is running?
Oct 19, 2012 | Refrigerators
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
My kenmore upright freezer won't stop beeping and everything is still frozen ???
hey.. look for a 9 volt battery. its for the memory and power failures .. so it needs to be replaced ..
Oct 19, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
If it gets cold enough check the thermostat
Aug 28, 2011 | Kenmore Freezers
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Refrigerators Logo
1,427 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
