PXE-E61: Media test failure, check cable
My E-Machine gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Can you help me fix this for free? I have an Acer Aspire 5920, it says check media cable and then it has black screen with "Missing operating system". i got a brand new hard drive and it still says the same thing. Help me please!
  • Allie May Nov 18, 2008
    My HP laptop just started doing this. After several control-alt-deletes and unplugging,and blowing on the connections and positive vibes (when it comes to computers I usually have the "I can't fix this" attitude so I thought I would try a different approach) it works. But, the next time I turn it on, it's back to the error message. FYI, Becky8fan, there are 104 pages of running posts by folks on nocrash.com with the same issue -- the error message seems to have mulitple possibilities (loose hard drive, incorrect boot order....... I will sit down and try some of their suggestions this week.
  • littlepigs99 Dec 04, 2008
    the problem is that you can't reload the operating system because it will not boot from the cd rom drive even if you put the cd rom drive as the first load up option...
    Sergeant:
    Champion:
  • 244 Answers
Check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Posted on Oct 01, 2008
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: PXE-E61: Media test failure, check cable
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Posted on Aug 31, 2008
dugiehowsa
  • 114 Answers
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Posted on Oct 10, 2006
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF  found no fault on the HDD. (full test took 45minutes)    Give it a try.  I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives.  Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck.
Bryan
Posted on Oct 21, 2007
  • 3940 Answers
SOURCE: PXE-E61 : media test failure,
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Posted on Jun 17, 2011
1720 s.m.a.r.t HDD detects imminent failure the computer cant boot-up.
if you haven't got a good back up, external to the hard drive, it may be too late
dead hard drives are mostly un recoverable
take it to a computer repair shop to make sure that it is not a boot problem
if the hard drive is failing, replace it with a solid state hard drive that has no spinning discs to fail
Jan 13, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Repeated Paper jams HP photosmart All in one C4200
you can try these steps presented on the HP support page. Paper Jam Message Displays on the All in One. I hope this helps
Jun 15, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
Speakers don t work
try checking windows control panal too see if you have drivers installed. if o.k. try sound icon to see if you have ticked mute box. here's the one that got me,the dvd playing program had the mute box ticked. re-launch dvd played/media played and un-tick. good luck
Nov 10, 2013 | Computers & Internet
Don't start up
check that all removable media is removed from computer, flash drives etc,if this message still appears the reinstall your os, there are several reasons for this error. You may have to replace your hard drive if that is the issue- you would know because after reinstall (if it makes it thru it) it will only crash again, this is much too big of a subject to sum it all up here and now, good luck... more questions just ask
Mar 30, 2013 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
Thanks.
Mar 08, 2009 | Computers & Internet
Computers & Internet Logo
5,672 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
