Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Plugged in the unit no power
I just bought the LG fron load washer and brought it home unfortunatley bought it from the paper clearly it has never been used the door was still taped shut and however after laying it on its side traveled 6 miles un load and plug it in absolutley nothing no poewer?? any thoughts...
Thanks
Ron
  • 706 Answers
Hello Ron,
If you are certain that the receptacle you are plugging the washer into is OK, then it is possible you have a bad cord, a fuse damaged or main circuit board damage. I suspect the cord or fuse might have the highest probability as the problem. I have attached a link for you to get the service manual and check out pages 14 -16 for troubleshooting details. If you can follow a schematic .. there are two fuse internal to the washer that may have gotten dislodged or damaged while in transit.. Also, if you open the washer up to gain access to this hardware, check that all connectors are properly seated on the main board and throughout the washer. You should do that with the washer unplugged
http://136.166.4.200/contents/Laundry/WM2688/WM2688_Service_Manual.pdf
Hope this helps you..
Posted on Oct 01, 2008
Washer will not turn on when you press the button but has been turning on by itself about every 4 hrs.How can you reset it and will it work?
Go to LG web site and see support see if others have this problem and if there is a recall. let them know about this problem and make them help you.
May 06, 2015 | LG WM2010CW 3.5 cu. ft. Front Load Washer
I just bought this thing and it worked at the guys house and now dosent turn on at all help thank you ...
Kevin, first check the wall outlet it's plugged into, to make sure it has power. It may have a loose wire connection or the circuit breaker for that line has been tripped. If you brought the unit home, sitting on it's rear or side, rather than on it's bottom, you will need to wait 6 to 8 hours before using it. As the refrigerant fluids and oil in the compressor need to run back in place.While you're waiting, check the outlet and the circuit breaker in your home's breaker panel.
Hope this helped you & thanks for choosing FixYa.
Aug 11, 2011 | LG Electronic Window Air Conditioner
I just bought the washing machine, got it home and it won't turn on. Do you know what could be the problem? It's an L.G front loader.
I would check the connections on the control board first to make sure they are plugged in good. If you don't find any bad connections then I would replace the main control board.
Apr 21, 2011 | LG WM-2277HW Front Load Washer
Elba WA50T54W1 water just overflowing not cutting of when full
water level pressure switch tube is clogged with lint or bladder in pressure switch is bad. disconnect power to washer open timer console look for a clear rubber hose disconnect fron switch and blow in tube a couple times reconnect tube and put unit on drain and spin for a second then retrying unit for water level fill put washer on small load water size and test if it continues to fill replace pressure switch...
Jan 23, 2011 | Washing Machines
How I fix an error code on a LG wm2669hna washer that says TE error
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
May 17, 2010 | LG WM-2277HW Front Load Washer
Unit will not power up. No lights, nothing. Acts as if there is no power at the plug, but I have verified there is power. Unit was working earlier today. Finished last cycle, didn't know anything was...
we had the same **** issue with the lg washer. we fought with the company as it was only 1 year old. do you know they asked us if it was plugged in hello my husband is an electrician. they came out it needed all new brains. to bad i cant give you the brains because now the piece of **** wont finish a wash even when empty reads ue. its going out on the sidewalk for any ****** who wants to pay to fix it .
Mar 13, 2010 | LG WM-2277HW Front Load Washer
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Ge front loading washer was plugged and not draining...we cleared the plug and now still not draining...the pump doesnt start pumping
Try looking at the inside of the pump, the impeller is likely plugged as well. unfortunatley you usually end up having to replace that part if it will not spin again.
Aug 26, 2009 | Washing Machines
Bought a new whirlpool estate washer today. brought it home. pulled yellow strap and removed long straight metal pin. (evidently broke 2 shipping pins off because they fell into their little plastic cups...
this is poor delivery,,jostled unit,,,you just broughjt it so your under warranty ,,by the time i tell you what to look for,,the warranty tech will be out ,,its better to let them handle it,,,if you open unit it will void your warranty...
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
122 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
