Question about RCA P52937 52" Rear Projection Television
RCA R52WH74 I turn my TV on and the green power light will come on for a couple seconds and I hear a high pitch sound then it turns off. Then after about 5-6 seconds the green power light comes on again for a couple seconds then turns off again. This happens a total of 3 times, but will never come on. I have been researching. I have check fuses FL221, FL231 and FL251 and they all seem fine. Not sure how to check the flyback. Any suggestions?
  • RCA Master
  • 8,617 Answers
The 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Oct 01, 2008
RCA R52WH74 HDTV Television MAKES NOISE POWERING ON
Thats the classic sign of a failed deflection board. You can get the ITC222A deflection board which comes with warranty and installation instructions from www.tvrepairworld.com its listed as the ITC222A remanufactured deflection board under the RCA CRT Projection Circuit Board catagory
Apr 01, 2012 | RCA HD52W59 HDTV Projection Television
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
When I push the power button on my RCA HDTV R52WH74, the green light turns on for about 5 seconds and then off. NO sound and no picture.
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
Jun 24, 2009 | RCA R52WH73 Projection Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv
a high pitch sound.. usally indicates a shorted horizontal transistor or possibley a flyback or both. common problem for this set
Dec 10, 2007 | RCA F31672ET TV
RCA P52937 52" Rear Projection Television Logo
313 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
