Question about IBM ThinkPad T22 2647 Notebook
Cannt get normal logon screen
When I boot up my T22, I get the msg 0175: Bad CRC1, stop POST task
Press to enter Setup
Press to choose temporary boot device
Does dot respond when I press either F1 or F12
Is it true that my mother board is not good?? IBM wants $900 for a new one.
  • 1,913 Answers
I think your hard disk had be dsectors
try to boot your system with win xp bootable disk
then go to trecovery console
then run
chkdsk /r
comamnd at recovery console
followthe instruction
Posted on Sep 30, 2008
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Mar 25, 2009 | IBM ThinkPad T22 Laptop
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
It sounds like your computer can?t read the boot sector on your hard drive which it needs to start up. The most likely cause is mechanical wear which usually starts gradually and gets worse over time. The computer ?system? can generally overcome these read errors through a series of read retries at first but as the problem progresses it becomes more difficult. When this retrying becomes more common users typically notice their computer making a ?clicking? noise. Mechanical hard drives failures not uncommon on laptops where power settings have the hard drive shut off after 5 or 10 minutes of inactivity. This is done to increase battery run-time; unfortunately this puts a lot of stress on the hard drive. My default settings for all my laptops is to not allow spin down (shutdown) while on A/C power and when on battery only to spindown after 30 minutes of inactivity. I would go into your BIOS setup (F1) and verify your hard drive is still defined and as long as you?re there take a look to make sure the date and time are still set correctly. If everything looks OK quit out of the BIOS, shut down and restart your laptop, several times if necessary. If you are lucky and this is the beginning of the read error cycle then eventually you will be able to start your PC. If you are successful immediately backup your data, collect up your restore CDs and install a new hard drive. If you have any other questions let us know what additional info you have. As always please don?t forget to rate this post.
Jan 31, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad T22 2647 Notebook Logo
194 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
