Question about Logitech 967437-0403 Keyboard
Mx3200 First the spacebar won't work andthenitworkstoowell.
Why has the space bar quit working on my keyboard? First it doesn't work, then when I go back to add a space it skips ahead 3 or 4 spaces. I checked the batteries-good, and cleaned under the spacebar-clean. Now What?
  • 903 Answers
Did you check to make sure that the springs and bar under the spacebar are seated correclty?
Posted on Oct 25, 2008
The spacebar on my laptop doesn't always leave spaces between words, what is wrong with it?
Inside the key, there is a metal bar the makes the spacebar key depress from anywhere you press it. Either this bar as unclipped from its hinges or they have broken.
Jul 06, 2014 | Toshiba Satellite A100-S8111TD Notebook
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
Samsung netbook N130 spacebar not working
manually pull up and remove the space bar, see if you can reconnect this. Check that something isn't caught beneath. like crumbs or
simply disconnected or not properly connected. Then re attach the space bar. Don't break it in half. inform me.
Sep 16, 2012 | Samsung NP-N130-JA01US Netbook
My new straight Talk phone won't unlock
hit the dash that is ABOVE and to the left of the OK then hit the space bar on the bottom. Space bar is the widest key on the bottom and actually looks like a typical keyboard space bar.
Jun 01, 2012 | straighttalk.com
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Space bar jumps three spaces Logitech MX3200
You can try and download the latest software from logitech for your model here.
Give that a shot.
Let me know what happens.
Jun 18, 2009 | Logitech Cordless Desktop MX3200...
Spacebar.quit.working.
Try to reseat the space bar again.
Feb 18, 2009 | Sony VAIO RA710G...
Pressing spacebar once will make cursor skip 3-5 spaces
I had the same problem on the Logitech MX3200 wireless keyboad. I simply unplugged my receiver from the USB port and plugged it back in. It's not the first time I've had this happen
Jan 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
Logitech 967437-0403 Keyboard Logo
495 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
