Question about Tissot T33.1.588.51 T-Touch Dial
Tissot T-Touch Hi, After changing the battery in my Tissot T-Touch the crystal does not activate so I cannot set the time or engage any functions of the watch. The digital time display works, but time is being clocked too quickly. Any suggestions for fixes I could do myself as watch has to be mailed overseas if it has to go to service centre. Thanks.
4 Suggested Answers
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
  • 5 Answers
SOURCE: the digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Posted on Apr 26, 2010
SOURCE: how do I change the time on the tissot 1853 touch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
Posted on Nov 08, 2010
Hello, I am from Greece and own a Tissot T-touch titanium. I just received it back from Tissot's service, I sent it for a battery change and a compass calibration, as it did not work well. As it was...
Its a good watch and good company, I would send an email to Tissot head office customer service. Praise the brand but insist you are not happy with the local service, having already had a failed repair. Hopefully they will accept it back for repair or replacement.
Mar 12, 2017 | Watches
The digital and hands display different times on my Tissot Touch
Dec 07, 2009 | Tissot T-Touch T33759851
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
Jun 30, 2009 | Tissot T-Touch T33159851 Wrist Watch
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
Dec 16, 2008 | Tissot T-Touch T33159851 Wrist Watch
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
T Button inoperative
get it serviced.. where in they will spray lubricants and clean the minute mechanisms..
Sep 09, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Synchronizing digital time with analogue time
hi...
press the T button until the crystal is activated.
press the middle of the glass until the time format appears (24hb Cm appears)
hold the T button for 5secs (SYNCHro appears)
move the hands until they are at 12 o'clock. ( + button moves the minute hand. - button moves the hour hand)
press the T button to set.
digital and analogue time are synchronised
pol
Jun 19, 2008 | Tissot T-Touch T33759851
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T33.1.588.51 T-Touch Dial Logo
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
