2002 sony #kp51hw40 flashes red light and then shuts off
    Sergeant:
    Champion:
  • 223 Answers
Count the flashes and the gap between the flashes as I know from experience the tv is giving you an error code in this way to say what is wrong. You should even be able to do this while the tv is in standby. Then once you have the code either consult your manual or try some of the sony forums to find out what the exact problem is. Hope this helps.
Posted on Sep 30, 2008
Red out of place on a sony kp51hw40
red and green lights repeat but tv not start
Sep 29, 2012 | Sony KP-51HW40 51" Rear Projection...
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
MY TV DOES NOT TURN ON AND I HAVE A BLINKING RED LIGHT MODEL IS KP51HW40
the blinking red light is an error code. How many times is it blinking and I will let you know what the error is indicating?
Aug 22, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony projection television KP51HW40/ bought in 2002 .
the flyback is bad when you get 8 blinks on the diagnostic led error code. If you need more assistance let me know
May 13, 2008 | Sony KP-51WS510 51" Rear Projection...
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
Top Televison & Video Experts
