Question about Whirlpool Dryers
Dryer belt havw a electric dryer and cannot figure out how to get this belt on,it doesnt have the idle pulley it just has a bracket like piece where the belt is supposed to go onto but there is not a opening to get the belt through.model # is leq9558kq1. Thankyou for any possible help
  • 943 Answers
Hi thanks for the question . look at the belt and motor you see the belt hanging down . with your right hand go to the right of the pulley . with left hand double the belt and push underneath the bracket , and install on motor pulley. hope this helps you thanks the appliance doc
Posted on Sep 30, 2008
How to replace a belt on a dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
I have the Dryer Repair Kit but can't figure out what part the Idler Bracket (of the Idler Pulley) hooks to. I unerstand that the belt loops through the bracket and then the motor pulley, but then it just...
Go to my profile... fixya.com/users/heatman101
then go down to the tips and go back about 11 pages....
find the brand dryer you have and the belt routing for your dryer....
there are many tips for each of the different brands..
heatman101
Apr 23, 2011 | Dryers
How to replace an idler pulley
The idler pulley bracket will mount on the base of the dryer, look for minute wear or shiny spots where the bracket has rubbed metal to metal on the base.
I will include a link for you to click on to see how to route the belt also.
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Jan 01, 2011 | Maytag PYE2300AY Electric Dryer
Belt Broke and pulley bracket came loose, where does pully belong
It goes into the front of the motor on the floor with the wheel to the left. You insert the belt between the idler bracket and loop it over the motor pulley.
The ribs of the belt need to be up against the drum for grip. It is best to have a person hold the drum while you do the pulley. Here is a page that shows various belt routings on different machines, yours is bottom right.
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
Putting dryer belt back on
The piece you see is called the idler pulley. Here's a link to a good description of how to change a dryer belt. It should show you what you need to do set it all right.
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 62872 Electric Dryer
Whirlpool dryer the belt has come off the pulley.
remove screws under lint screen ...press clips in at front corners of top and lift top remove 5/16 screws on inside top of front panel lift front off ck idler pulley if is roller type just reinstall loop belt from left and push through idler bracket and over motor pulley..bracket fits in slots in base if idler is glide type replace it with roller type 691366(i think)
Nov 15, 2008 | Whirlpool LER4634J Electric Dryer
I have disassembled my Whirlpool dryer and discovered the belt had come off. There was a part the is not secured fully to the dryer that has a wheel that appears to run against the belt, yet this piece...
there are 2 slots in base just under motor pulley the bracket fit into the the bracket will curve to left when installed properly..place belt around drum grooved side down..double belt at bottom and push through opening in bracket and around motor pulley roller on bracket will ride on top side of belt keeping tension on it
Aug 19, 2008 | Whirlpool Dryers
New dryer belt configeration
loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Jun 18, 2008 | Whirlpool LER5636P Electric Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
