Question about Dell Latitude D600 Notebook
Over-Intuitive Clicking My Latitude is taking considerable latitude with decision making on its own. I barely get the mouse pointer over an item and it unilaterally selects it. Windows close and open on their own. Fly out menus are a nightmare to control. This is extremely annoying as I work in Photoshop CS3 and I want to have control over when and where I click my mouse. Help - is there something I don't know about the set up of the mouse on this notebook?
    Genius:
  • 1,124 Answers
If your mouse is working erratically, or just not working the way you want, you might need to change your mouse settings.
You might want to check your computer or mouse documentation to see whether the manufacturer recommends particular settings.
To change your mouse settings
  1. Open Mouse Properties in Control Panel.
  2. Choose the settings you want on the Buttons, Pointers, Pointer Options, Wheel, and Hardware tabs.
To open Mouse Properties, click Start, click Control Panel, click Printers and Other Hardware, and then click Mouse.
Posted on Oct 01, 2008
  • Pablo Csaky
    Pablo Csaky Oct 01, 2008
    If doesn't work Try using and external Mouse
Lost th arrow on dell laptop
If the arrow does not appear, it usually means that Windows did not detect a mouse. A quick and easy way to test this is to plug in a USB mouse from a desktop computer. If your arrow returns, that confirms Windows does not see your mouse. If this *is* the case, then go into the BIOS screen (F2? when booting) and look through the menus to make sure mouse is enabled. Also make sure to look for an option under "Dock" that says something like disable mouse when docked. If plugging in a USB mouse does not make the pointer re-appear, then you may have windows problems. I'd try easy things first, like re-installing the mouse driver for your laptop. This especially if you have a fancy driver for multi-finger gestures 8-). While you work on this, try the Tab and ALT-Tab keys to move the focus around on your desktop. The Start menu also springs up with the Windows key. Space and Enter are like clicking. ALT-Enter like right-clicking.
Apr 01, 2014 | Dell Latitude E4310 Laptop
Dell PC Laptops latitude E6400 Touch pad slow
You can change the responsiveness of the pointer by going to Control Panel > Mouse > Pointer Options Tap > then increase the pointer speed.
Feb 14, 2013 | Computers & Internet
I want to deactivate the center blue colour touch/scroll botton
Usually the mouse control panel has options to disable the pointer or pad.
If you can't see it, download the latest pointer drivers from Dell for your model.
Mar 19, 2011 | Dell Latitude E5410 Laptop Computer (Intel...
Ppo1l dell latitude laptop mouse pointer keeps moving to top right corner. doesn't stay stationery
Your mouse pad is probably damaged.
Try to boot a different OS like Linux and see the behavior.
if the problem persist, you can disable the touchpad and use external mouse instead.
Mar 12, 2011 | Computers & Internet
The mouse moves on its own
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty or you might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 05, 2010 | Dell Latitude C610 Notebook
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
I need to disable Dell Latitude 620 track stick. It's not listed in the device manager and I HATE it.
If I get what your talking about go into mouse and pointers there you can change the right click left click around and a bunch of other options.
Jan 13, 2010 | Dell Latitude D620 Notebook
My dell latitude 610 touch pad is extremely slow
Try changing the pointer speed of your touchpad:
1. Go to Control Panel
2. Select Mouse
3. Click Pointer Options
4. Adjust the motion speed to fast (whichever you prefer)
Hope this helps.
Dec 07, 2009 | Dell F3534 Touchpad
Dell d600 mouse pointer jumps into corners if working on documents etc.; maybe if the system stores data in the cache or ram, the cursor wether jumps into the left down corner or moves slowly in directon...
What the issue is, is the eraser head mouse in the enter of the keyboard. When you type, it's putting uneccessary pressure on it, and it makes the pointer move. The only solution I know for this is to get the updated ALPS driver for the mouse, and disable the eraserhead (The updated driver gives you an option to do this), thereby using only the touchpad mouse.
Mar 15, 2009 | Dell Latitude D600 Notebook
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Dell Latitude D600 Notebook Logo
115 people viewed this question
Alun Cox
