Question about Refrigerators
Fridge not getting cold
Kenmore refridgerator not getting cold
  • 750 Answers
Hello swill688
Welcome to fixyz
You said, Your Kenmore refrigerator not getting cold
What is the model number?
And how old is it?
First check that the freezer is not filled packed full, and covering the air passage vents in the rear of the freezer! The fridge and the freezer share cold air from the compressor.
and his can cause the fridge to get warmer.
The other 2 things may be, either the coolant is low and needs to have the pressure checked then perhaps a sot of freon.
Or the thermostat may be malfunctioning!
I hope the freezer is packed to full, this is the easy way out of this situation!
Let me know!
Please remember to leave a rating before you leave us!
Thank You, Huuum
Posted on Sep 30, 2008
Kenmore elite refridgerator
check to make sure door is not stuck shut... or food may be blocking door outlet (usually located upper left hand corner of fridge side
Aug 29, 2014 | Kenmore Refrigerators
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
heatman101
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
298 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
