Question about Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi Regarding your post on how to fix the Proview PL926Wbi monitor, how do you remove the bad capacitors?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
PL926WBi
this trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 000 170DTLBMH PI 190DTLB Proview 899 AB0 220DTLB PCTH Power Supply...
Posted on Nov 11, 2014
  • 558 Answers
Unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Posted on Mar 21, 2009
My proview monitor stays on for 10 sec then goes black. but i can faintly see my page.
This indicates an inverter board failure, caused by bad capacitors that sometimes bulge at the top showing that they are open, an attempt can be made to repair or replace the board.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
I need to know how to open the monitor casing for the proview PL926Wbi
Remove all the screws and stand first, then use thin flat blade screw driver to crack it open at the bottom edge of the case and then work your way around and becareful on the ribbon cable attached to the front panel.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 13, 2010 | Proview PL926WBi 19" LCD Monitor
Sence yesterday morning when i turn on my Proview PL926WBi 19" LCD the power light flash's for a while with a black screen then come's on and work's fine. what is wrong with it??
It may have dying power supply due to bad DC filter caps, it will more likely to get worst and more components inside will be damaged.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a> he can make you a set of caps for you.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://www.badcaps.net/">http://www.badcaps.net</a></span>
Aug 26, 2010 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
On modern capacitors 2005 or up the capacitors can go bad and not even bulge at the top. I replaced a few in my moms flap panel monitor and found out that there were more that were bad and they didn't show any signs of damage but put your finger on one of those suckers and it burns like a smoking gun.
Apr 10, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor fix
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Oct 17, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor flickering then shuts off
Capacitors are bad. I fixed one. There was 470 uf that was blown.
Go to electronics store and buy 6x470UF 25v. Thats how i fixed mine
Sep 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
250 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
