Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Beeping only, and the coffeemaker won't brew at all
It seems that the coffee maker's program is out of whack. The coffeemaker slowed down, so I tried to clean it out with vinegar. After the cleaning, the thing wouldn't start at all. It just continues beeping even after plugging and unplugging; taking everything apart and putting it back together again. It's very frustrating as the coffeemaker was not an inexpensive purchase. It should last longer than a year!
  • vjsing78 Jan 18, 2009
    I cleaned my coffee maker with vinegar/water solution and did a couple of rinse cycles that seemed to work fine. Now when I go to make coffee it just beeps. I have checked the baskets and they are all in place and the lid closes. What else can I do?
  • 3 Answers
Check first that both filters (the water filter and the grounds filter) are in place correctly. Also check that the white tab in the grind cover moves freely when the lid is closed. (You can use a fork tine to test.) If that doesn't solve your beeping issue, contact or 1-800-726-0190. I did and they are sending me a new unit at no charge.
Posted on Jan 30, 2011
  • 8,596 Answers
Beeping indicates that a basket is out of place or the lid is not properly closed. Try opening/reopening the filter basket drawer.
Posted on Dec 17, 2008
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future..
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Slow to brew
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Nov 15, 2008 | Cuisinart Coffeemakers
Coffee maker keeps beeping
Many Cuisinart coffee makers beep at the end of the brew cycle.
Oct 12, 2008 | Cuisinart Coffeemakers
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
491 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
