Question about HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop
Presario won't boot - no monitor activity - long beeps
I have a Compaq SR1750NX which now will not boot at all. When I start the computer it makes long beeping sounds (dash - dash - dash in morse code) and the monitor shows no activity. Note that I generally leave it running and found it in that state one day after it was left on. I have re-seated all of the cables and cards (RAM, etc.), but to no avail. I have heard that it may be the video card, but it is on the motherboard so I'm not sure what I can do about that (if I put a PCI board in will it automatically override the primary video card?). Does anyone have a suggestion?
  • 60 Answers
It sounds to me that it could be bad ram.If you have two chips in the pc,try taking one or the other out to see if it will boot.
Posted on Oct 06, 2008
  • mirandar Jun 18, 2011
    You were ABSOLUTELY CORRECT!! I had the EXACT problem and it was indeed one of the RAM. I removed it and the computer booted just fine. Since so many others said dust may be a factor, which I had a LOT of - I removed the one next to the fan and it was that one.
Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
Feb 05, 2012 | HP Compaq Presario SR5262NX Desktop PC
My compaq presario/sr1750nx/ w sata drive/ amd 64 athlon. came with windows XP. I put put a new hard drive in the computer, with Windows 7 installed. I power up the tower, and the monitor stays blank?
Hi!
It is very unlikely to get the machine working when the windows 7 HDD was installed in a different type of computer, because all drivers installed with the operating system are related to the hardware from the other computer.
The best solution is to make a clean install, using the windows installation disk, and after that to download from Compaq's site the latest drivers.
If you still have reasons to use that previous installation, you can try to do the following:
1. Boot from the Windows installation disk
2. Follow all steps until it discovers the previous installation on the HDD
3. Choose to repair it (or better upgrade, if this option is available).
But doing so there only 50-50 chances to get it work, or to get it to be stable.
Hope it helped.
Regards,
Aug 20, 2011 | HP Compaq Presario Media Center SR1750NX...
Added new ram to compaq presario sr1750nx and worked fine at first.. now wont boot
Try taking the newly installed RAM out and re-seating it. If the persists you might have a bad block on the memory chip
Mar 12, 2011 | HP Compaq Presario SR1750NX PC Desktop
Compaq sr1750nx presario recovery
go to the compaq sight and download the drivers and software from them, burn to a disk and then run it
Sep 10, 2009 | HP Compaq Presario Media Center SR1750NX...
Can't get Picture on Monitor, replaced video card
Boot up into the setup, usually F2- in the video section look to be able to make a change from Onboard to PCI ...apply-save change and exit ...also make sure you have connected the monitor to the correct area...I , like a big dummy, have often just hooked it up to the first blue socket i saw and of course...not much happens.
I hope this helps you Fred, (if it came with drivers install them)
please leave rating, thank you kindly
May 04, 2009 | HP Compaq Presario Media Center SR1750NX...
Compaq presario sr1750nx controleur audio multimedia drivers
is that a pci sound card or the one on the motherboard ?
if it is the internal one... go to www.compaq.com and support... then enter the model number or have it autodetect your computer... install the sound driver for your operating system.
Please take a moment to rate this solution.. thanks
Jan 26, 2009 | HP Compaq Presario Media Center SR1750NX...
Monitor does not turn on
how old your monitor. check the all power cable. check vga cable. did your computer give 1 bip sound?
Jan 25, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
Problem with the sound system (compaq SR1750NX model)
You can download the driver here :http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Just input the necessary data about your system.
Jan 24, 2008 | HP Compaq Presario Media Center SR1750NX...
My computer will boot up and then then screen will go blank but the computer is still on. What is wrong with my computer?
Either u have a problem with WGA or monitor..Try to put another wga AND if still have a problem ur monitor need to reapir
Oct 24, 2007 | HP Compaq Presario Media Center SR1750NX...
HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
254 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
