Question about KDS K717s 17" LCD Monitor
Kds 917s lcd monitor
It get picture when i turn it on for 3 or 4 secondsn then it goes black. dont know if its worth repairing or not
  • 2 more comments
  • jrrodgersjr Nov 11, 2008
    I have the same problem except that mine won't even come on for two seconds. It flashes the start-up screen and then goes black. I have to hard re-boot the computer three or four times before it will come on and stay on. This, of course, is hard on the computer file system because I cannot see how far along in the boot-up it is. I try to wait until it appears that the hard drive is no longer being accessed before force a power off. I have tried turning on the monitor before booting (thinking that a warm monitor might make the difference - it didn't) and I have tried powering the computer and letting it go through a full intialization then turning on the monitor (maybe a cold monitor would make the difference - it didn't). Once the monitor is working like it should I can do a warm re-boot (restart) and it works like it should. Also once the monitor is on it will work perfectly until I shut everything down. The monitor is three years old. This prolem started this past weekend. (11 Nov 08).
  • keviquin Feb 17, 2009
    Same problem. I'd love to be able to get the case open.
    Any tips?
  • keviquin Mar 22, 2009
    How did you get the case apart? Screws out, but that front bezel is on tight.
    Problem Solver:
  • 10 Answers
Yup, that's correct. The capacitors are very cheaply made. I recommend replacing them all if applicable. Before replacing them you must allow the capacitors to discharge. You can just unplug the monitor for a few days. A manual way is possible. I will explain that in the lower portion of this post.
Remove the screws on the bottom edge on the screen. When the bezel screws are out place your fingers on the top edge on the bezel and press down towards the desk/table. The bezel should slide down and off almost like a PC side panel.
Remove the screws from the LCD pane and place masking tape around the edges of the LCD panel. These edges are crudely cut and are razor sharp.
Once taped pull the panel upward slowly. Note the three cables connecting the panel to the metal box behind it. These cables are the sync/video and CCFL cables. 5 connectors in total must be carefully removed with needle nose pliers.
Once the panel is removed, remove the screws from the metal box housing the power converter and LCD driver. Inside are two separate boards. They are connected on the edge via a small socket/pin connector. Remove the screws holding the power converter PCB. (The one that connects to the power plug port.) (I must stress the importance as stated before. DO NOT remove anything until you allow ample time for capacitor charge to deplete. Or have discharged them manually.) Using an analog (Needle meter not digital) Volt meter set it to 50V or close to. Place both prongs on the corresponding pole of the capacitor. (One capacitor at a time) You will see the voltage spike then slowly decline. Once the current is at zero move on to the other capacitors.
The bad capacitors will have brownish matter oozing out. Use your discretion to replace the faulty capacitors. I'd suggest replacing them all. Before removing them note their polarity and capacitance.
Pictures:kds 917s lcd monitor - c6290bd.jpg
Posted on Mar 24, 2009
Mine was also a capacitor problem..thanks to boxmodder above for pointing me to this. I ordered the caps from and they came in about 3 days. You have to know a little bit about unsoldering and soldering but it is not very hard. I changed all the ones in the photo above as well as one larger and one smaller. Here is my order info: 1 - 100uf400v item num: 565-1489-md
12 - 470uf25v item num: 565-1677-nd (ordered extra in case, only needed 6)
3 - 220uf25v item num: 565-1954-nd (ordered extra, only needed one)
soldered them in, and it works now. Total cost: $9.79. If yours is a cap problem like mine, it is work the time and money.
cheers! and thanks.
Posted on Apr 11, 2009
Mine was a no image, but cfl lights up problem. The AP4511GM mosfets transistors in an sop8 package blew off the board or cratered. One had a pinhole in the package from overheating.
They are on the underside of the switching power supply to the right , there are 4 of them. At $1.99 each on ebay, they are pretty cheap to replace. They are surface mount parts, so have a steady hand taking them off and putting them on.
Might as well replace the capacitors too.
Posted on Jul 07, 2009
I haved the same problem, it was not a capacitor problem, one of the lamps was burned so the protection circuit went off, thats why the monitor stays lit for a seconds and then its turn off... if you look closely there is image in the monitor but the lamps are off... if this is your case the solution is either buy a new inverter circuit board (expensive) or to try the solution that one of my co- workers and i find.
Goes like this.
Open the monitor and disarm everything so you can access to the four lamp conectors in the inverter board (its merged with the power source board so be carefull). After you identified the connectors you have to "trick" the circuit and make him "think" that all the lamps are working correctly. To do this just exchange the lamps connectors, instead of connecting 2 in each side, connect one and one.
Cn = Connector CnL = Connector Lamp
Normal Tricked MFCB
Cn1 ------ CnL1 Cn1 ------ CnL1
Cn2 ------ CnL1 Cn2 ------ CnL2
Cn3 ------ CnL2 Cn3 ------ CnL2
Cn4 ------ CnL2 Cn3 ------ CnL1
Try combinations and the monitor should stay lit cause now the circuit will "Think" the two lamps are functioning properly.
Pros.- Give that monitor a hard time again!!!!! and save big bucks..!
Cons.- Cause it will be working with only one lamp the monitor migth look "Tinted" on red color, or maybe another color, or maybe just dark, by adjusting the color options you can minimize this almost to 0.
Warning..!.... this is a standalone solution, i dont know if there is a risk of any kind (but the monitor its been working normally for more than a month now)...
Either way buying the inverter board is expensive and maybe its better to just squezze the monitor with this solution until stops to work and then buy a new monitor.
Hope it worked for some of you...(and this could apply to other monitors because the basis of the operation are much alike)
Would you like to know more......?
Posted on Feb 11, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 43 Answers
You have a set of bad capacitors on the invertor board.
replace C209,C210,C211,C212,C223,C224 - 470uF 25V
and C219 - 220uF
nine out of then of monitor with this failure will work fine after this replacement, if not you have a failing CFL tube.
Posted on Jan 18, 2009
Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
Sep 21, 2011 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
My kds k-92mdwb monitor goes black after a few seconds. How can I fix this?
brendadeese, You might be able to repair it. Well your husband or boyfriend maybe. If good with a soldering iron, solder-wick, solder, and $5-$12 in new filter capacitors. You should have visited YOUTUBE for video clips of "LCD monitor disassembly"and "LCD monitor repair" to see just what is involved with making BLACK SCREEN of DEATH go away. Most LCD monitors (98%) use same basic backlighting technology. Here are some repair options for you to ponder over! A. If KDS has a swapout program for BSoD units try it first! B. Contract out the REFURBISHMENT work to reputable local firm that knows exactly what is needed to do the work properly. C. Trade in for new unit. But remember that the tech in the back of the store is going to repair your unit with a little luck and have a nice monitor to give to his kids on Christmas, and won"t need to do it again till Christmas 2011 or 12. I would also recomend a visit to to learn what may be the cause of your BSoD. FYI If K92MDWb had a crisp, bright, colorful image just prior to BSoD, try doing the flashlight test so you will know if the units "switch-mode-power-supply" is in "full" or "partial" shutdown mode. 12fixlouie If this was of some help, please rate on fixya.
Nov 23, 2009 | KDS K92mdwb Monitor
Kds k717 screen is black what is wrong with it
The same problem happend on mine it was ac power converter box had to replace it twice but its been working for 3 years now note light was on both times
Nov 10, 2009 | KDS K717s 17" LCD Monitor
My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jul 03, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is...
if you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
Jul 02, 2009 | KDS Computers & Internet
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
Any tips on openong the 917s case?
Front and back of most LCDs shap together. Must be gently pryed apart.
Some KDS LCDs that have screws on the edge need to slide the front cover up a half inch to release from the back cover.
Monitor Mike
Feb 17, 2009 | KDS K717s 17" LCD Monitor
Hitachi CML174SXW B randomly goes black
Have you noticed if the monitor gets hot before it turns off?
Please, don't open a monitor and try to repair it yourself. It can be very dangerous and it's not worth getting injured.
Jun 18, 2008 | Hitachi CML174SXWB (Carbon) 17" LCD...
KDS K717s 17" LCD Monitor Logo
1,034 people viewed this question
Top KDS Computers & Internet Experts
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
