Question about Acer Computers & Internet
Mircosoft in hibernation
Startup repair cannot repair finish to shut down
    Genius:
  • 1,124 Answers
Please be more specific!
Posted on Oct 01, 2008
Shut down windows
Try holding the shift key down while selecting restart, then select "Turn off your PC."
Then power it back on normally. Startup will likely be a little longer than normal.
(The default "Shutdown" option in Windows 8 actually just hibernates your laptop.)
Sep 09, 2013 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Milton carroll,i have an acer laptop thats fairly new,5 months old.When it goes into hibernation after i go to bed,in the morning it does not want to startup properly.What can i do to fix this startup
You kn ow the old joke: man goes to see the doctor, raises his arm way over his head and turns the arm sideways, and says, "Doctor, it hurts when I do this!"
Doctor looks at the man, says, "Then don't do that!"So if you're having problems with hibernation, don't hibernate. Try using Sleep Mode instead, or simply do a shut down and restart it when you need it next.
There may be a problem with the hibernation system in your PC and if you leave it alone for a while, you may get an update from Microsoft which will fix that problem.
BTW, if you are not allowing your PC to get Microsoft's Windows Updates regularly, then you truly should, as they release little fixes all the time, and often there is not an exact explanation as to the thing it will fix, specifically. Just a "critical update" tag.
Cheers!
-a.
May 20, 2012 | Acer Aspire Computers & Internet
I have winows vista and it takes a few minutes for my pc to shut down and startup how can i get it to shut down and start up faster
Forget it, it takes what it takes. There is an idea of an external drive, that can be rigged that helps, but It is a waste of resoruces.
Consider using sleep mode, for faster cycling and only shutdown when you actually need to. If this is a laptop, consider hibernate. Both sleep and hibernate focus on faster start ups, but on laptop, if you use sleep and run out of battery, you can loose data that you were working on. ALWAY save and backup.
Oct 15, 2010 | Computers & Internet
Have had this lap top for right at 2 years,, just last few days, when I try to hibernate, it takes a long time to shut down, then when I start to "wake" it up, it shows that there was an un-nessary shut...
I don't know about the long shutdown time but I may be able to speed up the startup time.
(Assuming you have Windows Vista or 7)
Go to the Start menu and in the "Search" field type in "msconfig" (without the quotation marks" ")
Click the on "Boot.Ini" tab and check "NoGuiBoot". Now on the right where it says "timeout" change the 30 secs. to 15 secs.
Now click on the Startup tab. Tell me all the processes that are on here. If there's more than 15 or so then it's no wonder your computer is starting up slowly. This should dramatically speed up your PC and improve performance.
Jul 21, 2010 | HP Pavilion dv9000z Notebook
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby modes....windows hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
Acer extensa 4420 laptop, not working
when windows starts up it loads my files. but when its loading files. it cant load those files, so its stop working and shut down. if u r not expert. reload yor cop of windows.
Aug 23, 2009 | Dell Inspiron 6000 Notebook
Will not turn on, last time used, I turned it off manually?
Try this:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | HP Pavilion DV6500T Notebook
Computer windows will not come up
Try This:
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Hibernating
What do you mean shutting down the hibernating mode? Stop it happening when the battery goes low, or shutting down into hibernate mode?
Aug 20, 2008 | Compaq Presario Notebook
How do you get an acer out of hibernation?
If it hangs in hibernation the only way to get it out is to hold the power button down until it shuts off, and reboot. If it continues to hang up in hibernation, do a system restore o system repair with the recovery or operating system disc. If the problem persists after the restore or repair, then you will need to disable the hibernation.
Jul 25, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
